1. jeff3511's Avatar
    Hello,
    Just preordered the S9; will be upgrading from S7.
    Some of my apps and data are on a SD Card. I plan on using Smart Switch to transfer from the S7 to S9. Do I leave the SD Card in the S7 before using Smart Switch or do I install the SD Card in the S9 and then perform Smart Switch?
    Thank you,
    Jeff
    03-04-2018 08:30 AM
  2. chanchan05's Avatar
    Leave the SD card in the S7.
    03-04-2018 08:53 AM
  3. rjack22's Avatar
    What is Smart Switch? Is it the Samsung app to transfer content? If so, does it transfer all of my apps and app settings? It it better than Verizon's transfer app?
    03-04-2018 09:47 AM
  4. chanchan05's Avatar
    Yup. It transfer to a Samsing, transfers all apps and settings like homescreen layout, folder layout, all the phone settings, wifi passswords, pictures, contacts, call logs, messages, etc. Not all apps support app data transfer though.
    03-04-2018 10:04 AM
  5. rjack22's Avatar
    Thanks. Sounds like the way to go. It will save me a lot of time when I get my new S9!
    03-04-2018 10:33 AM
  6. Dualmonitors's Avatar
    May i ask what doesn't get transferred and how would one go about transferring those items after Samsung Smart Transfer is done, please? Thank you.
    03-04-2018 12:38 PM
  7. chanchan05's Avatar
    Some app data/game saves. Most apps have their own backup anyway, so use that. Or use Helium.
    03-04-2018 05:28 PM
  1. Anyone dumping the note 8 and switching to the S9plus
    By Oscar Maradiaga in forum Samsung Galaxy S9 & S9+
    Last Post: 03-11-2018, 01:17 PM
  2. Switching back from iPhone X, Note 8 or V30? Opinions needed
    By NIZMOZ44 in forum Samsung Galaxy Note 8
    Last Post: 03-08-2018, 08:28 PM
  3. Replies: 5
    Last Post: 03-04-2018, 08:36 AM
  4. Update error from Android 4.4.4 on Vodafone Smart Tab 4G
    Last Post: 03-04-2018, 06:48 AM
  5. Using Smart Switch to transfert data from Galaxy S3 mini to Galaxy A5 t
    Last Post: 03-02-2018, 03:17 PM
