1. rMBA13's Avatar
    Since the Macbook 2016’s charger is much longer, I was thinking of using this USB-C charger to charge my pre-ordered Galaxy S9 every night. Is it safe? Will it void the warranty?
    03-05-2018 09:23 AM
  2. Gayle Lynn's Avatar
    I do, with S8+ and Note 8. I also use Samsung new 2018 wireless stand and an older flat (lighted) fast charge wireless pad.
    The Apple charger is overkill, but seems perfectly safe.
    03-05-2018 01:23 PM
  3. Rukbat's Avatar
    Just look at the Output line on the label. If it puts out 5 Volts, it's safe. It doesn't matter if it puts out 5 Volts at 700mA or 5 Bolts at 30 Amps, it's the voltage rating that matters. If it produces enough current, the phone will draw what it's designed to draw. (Your home is probably rated at around 22,000 Watts or 110 Volts at 200 Amps [or 220 Volts at 100 Amps, depending on where you live], but a 100 Watt light bulb still only draws 100 Watts [~1 Amp at 110 Volts, ~0.5 Amps at 220 Volts.)
    03-05-2018 03:16 PM
  1. My Note8 S Pen works without touching the screen
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 08-21-2018, 05:26 PM
  2. HTC U11+ to Pixel XL 2?
    By jcdub in forum HTC U11+
    Last Post: 04-14-2018, 01:13 PM
  3. What is Galaxy S9+ estimated battery life?
    Last Post: 03-05-2018, 09:32 AM
  4. my talk to text feature is missing on galaxy s8
    Last Post: 03-05-2018, 09:16 AM
  5. delete
    By murkoh in forum Ask a Question
    Last Post: 03-05-2018, 09:03 AM
