1. btkbtk's Avatar
    Hi
    I have the SM 323 VR headset. The one that came with S7. It also have the USB type C adaptor.
    Do you think S9+ will work with this headset??
    Thanks in advance.
    03-06-2018 02:03 PM
  2. CKwik240's Avatar
    I can't see how. There really isn't a way to get an adapter to fit between the phone and the headset. Not to mention even if you somehow did, the image in the screen would no longer line up with each lens.
    03-09-2018 03:14 AM
  3. anon(1733)'s Avatar
    The adapter swaps out of the vr set. I think it would fit. They only switched the vr set for the note 8 and even the note 8 fit in the old set. It's snug but it fits. You should be good.
    03-09-2018 04:18 AM
  4. mrcrusha829's Avatar
    The white headset does not come with an adapter. I am looking at one right now. The one that came with the S8 does have an adapter for the VR headset and that one should work without issue.
    03-09-2018 06:48 AM
  5. 808Mobi's Avatar
    Ebay is having a site wide sale today with 20% off everything. You can get a good deal on the 2017 Gear VR.
    03-09-2018 08:54 PM
  1. my samsung tab is not updating
    Last Post: 03-06-2018, 02:10 PM
  2. Samsung S7 LCD repair has cracked in the same place
    By wilsonmt12 in forum Samsung Galaxy S7
    Last Post: 03-06-2018, 01:09 PM
  3. Buy from Samsung, Best Buy or ATT?
    By geraldem in forum Samsung Galaxy S9 & S9+
    Last Post: 03-06-2018, 11:58 AM
  4. My Samsung S6 Keeps on Freezing - Process System is Not Responding.
    Last Post: 03-06-2018, 11:04 AM
