03-14-2018 01:20 PM
87 ... 234
tools
  1. rushmore's Avatar
    Mixed overall, but seems the 9810 is doing good and the 945 is not doing so good.
    03-12-2018 11:05 PM
  2. arsenal74's Avatar
    I have the exynos, battery is average not terrible but worse than v30 or 2xl. 2% an hour sitting on my desk doing nothing. And losing 10% overnight in flight mode and aod off.
    03-13-2018 03:34 AM
  3. waveuk's Avatar
    Can you share your stats? It has to be an app draining the battery.
    Overall I see very good battery without any adjustment.
    Bluetooth is all an and connected to my smartphone and I leave NFC also on.
    03-13-2018 03:55 AM
  4. ScottsoNJ's Avatar
    I'm considering the Mate 10 Pro as an option myself. How is the battery life and standby time on the regular Mate 10 with the QHD LCD screen, as opposed to the Pro with the 1080P AMOLED? Are you able to see the screen in direct sunlight? Finally, how is the audio through the headphone jack? Does it sound full and rich to you? I do like the fact that the fingerprint scanner is on the front of the phone on the regular Mate 10, as well as the headphone jack.
    I've seen reviewers bash EMUI as being redundant. One thing I appreciate with EMUI and iOS, that they obviously ripped off, is the fact that you can view up to nine apps in a folder. I hate Android folders that only allow you to see four apps. The nine per folder just looks cleaner to me. Are you having issue with EMUI?
    You might want to also check out the Honor View 10. Seems like Mate 10 pro without some of the features and a whole lot cheaper
    03-13-2018 09:25 PM
  5. Itsa_Me_Mario's Avatar
    i'm willing to bet that Samsung can improve standby time with a software update. We are still very early in the process and this is something they were doing very well at for the last couple of generations.
    03-13-2018 09:33 PM
  6. rushmore's Avatar
    Still torn on keeping my pre-order, since battery life and standby time still are great with my 8+. Decisions....
    03-13-2018 10:16 PM
  7. durandetto's Avatar
    I have to say I'm impressed so far.
    03-14-2018 12:48 AM
  8. LPRodgers's Avatar
    I would say during the setup process a lot of things can be synced and this thing could be a data chewing night mare, if you set it up right it can be downright amazing.
    Make sure you're not syncing the Google backup cloud and the Samsung cloud all the time, do it manually when you can or this phone will run all day. I also personally use the bixby button, but turn off bixby wake to voice, and I use Google assistant with smart Lock enabled voice. Turn off the face and Iris detection and use that wonderful fingerprint scanner, and lastly in navigation bar tick open with home button hard press this way you can open it facing you and when you're holding it. I get amazing battery life with this setup, today I couldn't even get it to 45% left with 3.5 hours of SOT blaring at 60% for 16 hours.
    03-14-2018 12:58 AM
  9. bbzsget's Avatar
    I have to say I'm impressed so far. https://uploads.tapatalk-cdn.com/201...0ad43bfadf.jpg
    Lol where are the apps you used??were you just looking at a black screen cos it sure looks like it.
    03-14-2018 03:18 AM
  10. durandetto's Avatar
    I don't use a bunch of apps, but this was with my initial setup. Downloading updates, restoring backups, tweaking the settings and browsing the forums. And technically yes I was looking at mostly black screens. I run a dark theme and if the app has a night mode I run that. I was only stating that for my usage I was getting great battery life especially compared to my note 8. YMMV.
    03-14-2018 08:46 AM
  11. bbzsget's Avatar
    Ok because its odd that none of the apps are appearing at the top below the screen as mine is showing
    03-14-2018 12:23 PM
  12. durandetto's Avatar
    That is kind of weird, because Tapatalk should have been near the top. It's probably my most used app and I was on it for a good portion of my sot.
    03-14-2018 01:20 PM
87 ... 234
  1. Music Player app strange behavior in Shuffle mode
    By UglyStuff in forum Android 7.0 Nougat
    Last Post: 03-11-2018, 08:08 AM
  2. Bluetooth battery gauge
    By Mooncatt in forum LG V20
    Last Post: 03-08-2018, 05:31 PM
  3. the data gets on in my galaxy s4 how can i fix it???
    Last Post: 03-08-2018, 03:24 PM
  4. Why is my andriod 8.0 update taking so long?
    Last Post: 03-08-2018, 01:12 PM
  5. Why is there a dark spot in my photos taken on the Honor 7x?
    Last Post: 03-08-2018, 06:07 AM
