1. Kayla Sanders1's Avatar
    What should i expect in terms of speed, camera quality, etc, Will there be a noticeable difference?
    03-09-2018 03:12 AM
  2. chyeo1979's Avatar
    I never used a Note 5, but i feel will have quite big difference. S9+ really is quite a beast in every area.
    03-09-2018 03:22 AM
  3. anon(1733)'s Avatar
    I hope this is a real thread. Everyday there's a new thread about the same thing by a new user who signed up the same day. Yes if you need a new phone and like samsung the s9 is better than the note 5. Kind of a no brainer.
    03-09-2018 04:16 AM
  4. Kayla Sanders1's Avatar
    This is a real thread. -.-; I stalk these forums alot and trying to get advice on if i should switch.
    03-09-2018 05:03 AM
  5. anon(1733)'s Avatar
    Then yeah most definitely. It would be a great upgrade. If you use the spen a lot then perhaps get the note 8 or wait for the 9. But otherwise I would get the s9. If you don't want to spend as much you can find great deals on the s8 also.
    03-09-2018 06:19 AM
  1. Replies: 3
    Last Post: 03-09-2018, 03:59 PM
  2. Replies: 1
    Last Post: 03-09-2018, 01:51 PM
  3. How to send pictures on Google pixel 2
    By jaleelhamidd in forum Ask a Question
    Last Post: 03-09-2018, 01:03 PM
  4. Set WiFi Hotspot timeout to anything other than 5 or 10 minutes?
    By UglyStuff in forum Android 7.0 Nougat
    Last Post: 03-09-2018, 02:26 AM
  5. Pixel Live Earth Wallpapers On Exynos Note 8
    By stinger16 in forum Samsung Galaxy Note 8
    Last Post: 03-09-2018, 02:12 AM
