06-13-2018 12:52 AM
90 ... 234
tools
  1. KP8819's Avatar
    ok, I give up... how the heck do I post a gallery image (screenshot) of my battery life? the only options I'm seeing are emojis, GIF, STICKERS... where's the paper clip to add image? I'm on the app on my S9+ not a computer ๐Ÿคจ
    On the app you can reply with quote to any post then delete the quoted post. There is an attachment button(paper clip) that will allow you to attach screenshots/pics.
    If it's not taking you to your gallery idk what's up then...
    Denisew 1972 likes this.
    06-03-2018 10:23 AM
  2. krisqz's Avatar
    How does the battery life on the S9 and S9+ compare to that on the S6 and Note 5? I'm currently using a Note 5 and it's okay. Needs about 2 full charges to get through the day. I had an S6 but it was absolutely abysmal. It literally needed 4 full charges each day. Thanks
    I switched from S6 to S9 last week. The difference in battery life is like next generation. My S6 was terrible at the end. Half an hour of Google Maps on a sunny day with auto brightness was taking 50% of the battery. You can feel it's 4 years of difference with S9. Same scenario takes 8%. I'm super happy with the upgrade.
    06-03-2018 12:50 PM
  3. Jrome.brooks's Avatar
    I just got the s9+ a few days ago got the screen brightness turn almost all the way up and with sync on bluetooth on I get up to 9 hours with moderate to heavy use and that's great compared to the note 8 which I had to turn off location and sync and turn the screen brightness down to half and to get the same results
    06-03-2018 02:23 PM
  4. Denisew 1972's Avatar
    Thank you so much! That was driving me nuts! ๐Ÿ˜ Even a Google search couldn't help me... applause to you sir!
    Attached Thumbnails Battery Life - Results-8291.jpg ย
    KP8819 likes this.
    06-03-2018 02:27 PM
  5. Jrome.brooks's Avatar
    Thank you so much! That was driving me nuts! Even a Google search couldn't help me... applause to you sir!
    That's really good if you turn off AOD you would have even better battery life
    06-03-2018 02:28 PM
  6. Abbers727's Avatar
    At what percentage should you charge your phone and at what percentage would you stop charging your phone?
    I've been charging it up to 100%
    06-03-2018 11:46 PM
  7. KP8819's Avatar
    Glad I could be of assistance ๐Ÿ™‚
    No need to turn it off but to extend battery life I just keep my phone face down and it keeps it off until needed.
    06-04-2018 12:34 AM
  8. Ahmed Al Wakeel1's Avatar
    I switched from S6 to dual sim S9+ exynos... battery life is of another age... cellular reception is super solid from both sims and with 4g and sync and location and aod on i am getting 5 and half hours of SOT...
    On the S6 I barely would make it to 2 and half hours with everything off
    06-04-2018 06:55 PM
  9. Jrome.brooks's Avatar
    I had my phone off the charger since 4:20am I was on 3% by 3:04pm with screen brightness almost all the way up sync on location services on very happy with s9+
    06-04-2018 07:05 PM
  10. Pickle528's Avatar
    I am very satisfied with this bad boy. It's much better than my S6, and if I used that from 100% to 0% continuously i could get maybe 3 hours out of it. Mind you that when it was new I could only get about 5 hours out of it. I can easily get 10 hours of constant usage on this (have not been able to test that ๐Ÿ˜‹) and this morning I took my phone off the charger at 730am, didnt use it much until about 5pm, used it for music and social media at 5pm and then used it a lot from 9-1030pm and now I'm at 32%. It says I probably have about 4 hours left too. Wow!! 19 hours on light usage and 8- 10 hours on constant usage. I'm happy with that.
    Attached Thumbnails Battery Life - Results-7274.jpg ย
    06-05-2018 01:38 AM
  11. Denisew 1972's Avatar
    I know right... I kinda like it though. Like a little desktop clock.
    06-06-2018 06:18 PM
  12. jimbl's Avatar
    This is good to hear. I have the S6 still, and am seriously considering the S9+.
    06-07-2018 10:14 AM
  13. chevyman29's Avatar
    845
    I'm really loving this phone signal is great and battery is way better than my s8
    6 hours of screen and over 4 hours of talk time is great
    Attached Thumbnails Battery Life - Results-screenshot_20180607-232833_settings.jpg ย
    06-08-2018 12:39 AM
  14. LCW's Avatar
    Got the S9 Saturday but today was the first day I used it more normally and stayed of the charger for any top ups. This is my S9 not a Plus.
    I'm coming from an iPhone X so while not quite as good I find this not too bad actually.
    Should get a little better yet with a few more charge cycles and the newness wears off a bit.
    06-12-2018 11:08 PM
  15. raynanda kho's Avatar
    So i have bought this s9 last sunday
    But i found the battery really drained fast
    Can someone help me ?
    Attached Thumbnails Battery Life - Results-screenshot_20180613-114959_settings.jpg ย
    06-13-2018 12:52 AM
90 ... 234
  1. Battery - Galaxy Note 10.1 2014
    By lbabus in forum Batteries
    Last Post: 12-22-2018, 04:28 PM
  2. Exchange using up battery - what is this?
    By sethm1 in forum LG V30
    Last Post: 06-04-2018, 10:20 AM
  3. S9+ battery not charging
    By AlexiM in forum Samsung Galaxy S9 & S9+
    Last Post: 03-14-2018, 09:31 AM
  4. TMobile Life
    By dmateo in forum HTC U11 Life
    Last Post: 03-11-2018, 05:58 PM
  5. Galaxy S9 plus recommended first battery charge
    By Kko 5 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-09-2018, 07:00 PM
