09-27-2018 12:39 PM
54 123
tools
  1. neil74's Avatar
    Only had my S9+ since Saturday and I know battery often takes time to settle but I'm not impressed so far
    My main issue though is overnight, I leave my phone on but in flight mode and aod off and last night it dropped 11%. Going to test again tonight but this seems excessive and no clues in battery stats (either stock or gsam)
    Anybody else experiencing this?
    03-12-2018 03:24 AM
  2. DamianP's Avatar
    I assume you have AOD on? based on the S8plus and Note 8 a 1% drop per hour is not uncommon with AOD on.
    Letting it settle out after a few days should also help.
    03-12-2018 08:12 AM
  3. neil74's Avatar
    Aod off for me. always have it scheduled to switch off at 10:30 pm
    03-12-2018 08:43 AM
  4. mango1228's Avatar
    Remember it takes the battery a few days to settle. And there is an update being sent out for all the issues for the peeps that got early devices. In south africa we got out devices on the 5 march. It will get better
    03-12-2018 08:51 AM
  5. arsenal74's Avatar
    Same again last night, 10% drop
    03-13-2018 03:40 AM
  6. waveuk's Avatar
    Can you share your battery stats? It has to be an app draining the battery.
    I am seeing very good battery life also on idle.
    03-13-2018 03:52 AM
  7. dov1978's Avatar
    Did you set it up as new or from a backup? This can make a huge difference to battery life on a new phone
    03-13-2018 03:59 AM
  8. dov1978's Avatar
    03-13-2018 03:59 AM
  9. arsenal74's Avatar
    It's all in android system and kernel, ok it was 9% not 10%
    Losing large battery % overnight (standby)-screenshot_20180313-061110_gsam-battery-monitor-pro.jpg
    03-13-2018 05:03 AM
  10. arsenal74's Avatar
    Set up as a new phone.
    03-13-2018 05:03 AM
  11. Rukbat's Avatar
    Try Wakelock Detector (see Wakelock detector with non-rooted phone if the phone isn't rooted.) If something is waking the phone all night, that can do it. Also a weak mobile signal (not in neil's case - his phone is in flight mode) drains more battery. And Play can be updating a lot of apps that have gotten updates since they were put on the phone (again, probably not in neil's case).
    But most phones show "bad battery life" the first few charge cycles - it's the nature of lithium batteries.
    03-13-2018 02:45 PM
  12. waveuk's Avatar
Name:	Screenshot_20180313-061110_GSam Battery Monitor Pro.jpg
    What was your SOT at that point? There are a few apps that should not consume battery if not used.
    03-13-2018 03:11 PM
  13. msm0511's Avatar
    It's a Samsung phone. I had The ill-fated Note 7, S7 Edge, and the S8+. The standby time was bad on all 3. Tried with and without AOD, all different kinds of settings, everything I could think of. One thing I figured out was that Samsung phones get better than average battery life during use, but standby has never been their strong suit.
    The S8+ got better with time though after some Samsung updates. Keep an eye out for those.
    andrew_ackley likes this.
    03-13-2018 04:54 PM
  14. Lecrae116's Avatar
    Im thinking about doing the sd card backup via smart switch and then I'll put that sd card in my s9 plus. Will this cause issues?
    03-13-2018 05:39 PM
  15. sqa4life's Avatar
    As long as the battery last the whole day, I wouldn't complaint.
    Let it sit on my wireless charger over night and woke up with 100% charged and ready for another day.
    03-13-2018 06:24 PM
  16. tcdude's Avatar
    What I've been doing lately is turning it off at night it's not like we need it while sleeping unless it's used as your alarm
    03-13-2018 07:00 PM
  17. Kko 5's Avatar
    Dear friend thx for the tip. I had the same issue for 5 days now and today decided to make a reset as new since at 1st day I made from a back up. It looks like that my battery stats will be better under this new reset
    03-14-2018 02:55 PM
  18. andrew_ackley's Avatar
    Lol every new Samsung release this thread pops up. It's Samsung they all do that crap. A pixel on the other hand (for reference) does not.
    03-14-2018 10:39 PM
  19. waveuk's Avatar
    Mine got even better with the update.
    Overnight (7.5 hours) lost only 4% battery.
    With a bit more of 50% battery left I already got 4 hours SOT. Where off half was on Wi-Fi and half 4G and my smartwatch connected all the time.
    This is the exynos S9+
    03-15-2018 03:10 AM
  20. Victor Hernandez Jr's Avatar
    I'm guessing people don't cycle the batteries anymore you got to fully charge it when it's brand-new Let It Die completely keep following this pattern for a couple days
    03-15-2018 03:12 AM
  21. dov1978's Avatar
    I'm certainly no expert but I was under the impression that you shouldn't be letting modern lithium ion batteries die completely as it harms them? I thought they needed 'little and often' top ups to keep them healthy
    03-15-2018 03:42 AM
  22. CKwik240's Avatar
    Yes and no. You don't want to take a lithium battery below a certain voltage threshold. But phone manufacturers don't allow the phone to drain a battery to that point anyways.
    03-15-2018 05:03 AM
  23. dov1978's Avatar
    Yeah I'm sure even when your battery shows 0% it's actually a few percent higher to allow for this. I'm just thinking of the issues a lot of people were having with the Note 8 and it bricking when people let the battery die.
    03-15-2018 05:09 AM
  24. ozzy88's Avatar
    Man mine has dropped 25%! Its driving me crazy! Not using AOD and I haven't found anything wrong with any app!
    09-17-2018 08:43 AM
  25. Hermes Hidayat's Avatar
    Erm... My S9+ drops around 5%-8% when i sleep. 11% is a bit too much in airplane mode though. Did you close apps?
    09-17-2018 01:09 PM
54 123
  1. Replies: 3
    Last Post: 03-15-2018, 01:38 PM
  2. Replies: 1
    Last Post: 03-13-2018, 02:49 PM
  3. Battery life
    By raileena131 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-12-2018, 12:37 AM
  4. Battery life
    By evohicks in forum Samsung Galaxy Note 8
    Last Post: 03-11-2018, 09:25 AM
