Ok hello again everyone.
I posted the original item about dropping calls on the S9+ and after just over 2 weeks of use and fault finding with Samsung the result is that my phone IS BEING RETURNED AS FAULTY.
Just to be clear - this is nothing to do with poor signal strength or whether this S9 gets weaker/stronger signal than other phones - the signal strength shows the same db and % signal strength as my S7 EDGE (see first page in this thread).
The issue is that the S9+ CONSISTENTLY DROPS CALLS, every few minutes, it did it 3 times during a 20 min call to Samsung themselves. It is very repeatable - I just need to call my voicemail and wait a few mins and the call is dropped. This is the issue and it makes the phone pretty much unusable unless you don't make phone calls very much that is or enjoy re-dialling every few mins. It seems to be mainly when the signal is less than full strength although not always.
The phone came direct from Samsung and is unlocked.
SM-G965F (S9+ HYBRID SIM 128GB)
Android 8.0.0
Security patch level 1st March 2018
Network is Vodafone UK
This is what I tried...
- Making outgoing calls vs receiving incoming calls
- Changing settings from 4G+ to 3G/2G autoswitch
- Changing settings from 4G+ to 2G
- New replacement SIM card
- Factory reset the S9+ phone and installed with standard google / samsung apps
- Factory reset the S9+ phone and installed with minimum possible apps - deselected every feature possible, no WiFi
All of the above made absolutely NO difference at all.
Also
- Calls from different locations up to 60 miles away - so not the cell tower
- Static and while moving in a car - the transitions between cell towers were very noticeable - the displayed signal went to zero, the call audio dropped and then a few seconds later (3-5 maybe) the signal came back and the call resumed
Put my SIM in my S7 and it's totally fine again - people commented immediately on how much clearer the call was and the call did not suffer from the voices fading out and dropping. I also don't get poor cell tower transitions - it is seamless again as you would expect.
Conclusion - this S9+ phone has a fundamental technical issue. When I get the replacement handset I will find out if it's just the one I had or if there's a general design flaw with the S9+.
Overall pretty terrible for a "flagship" handset, incredibly frustrating and simply unusable for making calls. Unless my replacement resolves this it will also be going back to Samsung like the first one and I will not be using an S9 any more.
Android 8.0.0
Also
