02-07-2019 11:24 PM
61 123
tools
  1. Krystle P's Avatar
    I know I'm really disappointed about it too, I've always used the spam protection option on my Note 8,S8,S7 edge and now I can't unless I wanna not know I've got any missed calls. Its intermittent too, I tested it I missed called myself 6 times and only 3 times it notified me of the missed call. I then switched off spam protection and tested again and all my missed calls notifications showed. So there's some kind of conflict with that service on the S9. I don't know if Samsung is aware of this. Hopefully they'll be a fix. Fingers crossed.
    It took forever but tried many of these suggestions and nothing works so I just decided to reset all app settings... IT WORKED....you won't loose any data and you can keep you the spam blocker and anything else you may have disabled to fix this. Hope it helps..ps I know it's a late reply ๐Ÿ˜‰
    05-31-2018 02:39 AM
  2. Jadaress1's Avatar
    The april update fixed everything for me, the one with the april security patch, I tried eveything before that including the one you mentioned, actually reset them twice but nothing. Thanks
    05-31-2018 04:18 AM
  3. keminoak's Avatar
    Was having the same issue and searched a number of threads. Solution for me:
    Settings/Notification/Advanced (top right corner)/contacts
    Now it works.
    06-10-2018 05:38 PM
  4. Grubb3r's Avatar
    Hi, I just got my new S9 last week however I am not getting missed calls notification. Have gone though all the settings and third party apps but no joy. Had upgraded from an S7 and never had that problem before
    I think I fixed this on my phone. I went into the regular settings, "notifications", and on the top right, I went to "Advanced". I found that my Contacts were blocked from notifications, which included missed calls. I changed this and it seemed to have worked!
    06-18-2018 08:15 AM
  5. robertkoa's Avatar
    Hi, I have just found a solution that has worked for my phone:
    Go to settings -> Notifications -> Advanced (top right) -> Advanced Notification Settings -> Contacts
    Then click on default, missed calls and voicemails seperately and change the importance and sound etc.
    This has worked for me, I hope it works for everyone else.
    When I try that I can check badges BUT the other options can not be turned on ...click and nothing.
    Seems like some menus are incomplete and this is two weeks old S9 Tmo.
    For example in Calls Menu - I SHOULD be able to FILTER missed calls / dialed calls etc.
    07-10-2018 12:22 PM
  6. robertkoa's Avatar
    Just in the Recent Calls or Dialer...
    I am getting notifications for missed calls but I can't SEARCH in Menu for dialed calls / missed calls ...etc..
    I also could not COPY a number to text to someone else ......not a business like dialer ...
    Previous Galaxy Alpha was like Note Series Menus
    07-10-2018 12:38 PM
  7. robertkoa's Avatar
    Previous Galaxy Alpha was like Note Series Menus .
    I have badges now and notifications but can not filter / search for dialed calls but CAN list Missed Calls ...
    Can't copy /paste numbers yet...
    Tricky Secret Code Menus lol
    07-10-2018 12:50 PM
  8. Toliska162's Avatar
    For the problem was that clean master was activated and all notifications cleaned automatixally. Open clean master or any else similar app and deactivate contacts automatic cleaner
    08-26-2018 03:51 AM
  9. racedog's Avatar
    If you've got Clean Master on your phone you've got bigger problems than lack of call notifications. I just don't get people still putting Cheetah apps on their phones after all that has been written about them in these forums.
    08-26-2018 07:37 AM
  10. eseijas's Avatar
    Guys, I found it! All resolutions mentioned here are absolutely correct and may help in resolving the issue with some of you, but for me none of them was successfull, until I recognised that I have a third party device management application "clean master" that has permission to clean junk notifications from the device, once I disabled this and blocked the access all notifications start popping up normally ๐Ÿ˜
    If you have any of these apps installed on your device such as battery doctor, vga anti virus or clean master, it worth give it a try and block thier notification clearing permission.
    Chack and let me know ๐Ÿ˜‰
    Love you Candy!!!! Hours trying everything that was posted here but your advice was right on target. I worked beatifully right.
    12-01-2018 01:12 AM
  11. Anthony LaVear's Avatar
    This worked for my wife's S9+. I would assume that any third party calling apps, i.e. WhatsApp, Kik or something, blocks the notification from the contacts. Why the contacts drives phone notifications...that's a question for another day!
    02-07-2019 11:24 PM
61 123
  1. how to share a widget from on android device to another?
    Last Post: 03-13-2018, 03:13 PM
  2. S9 Keeps dropping Wi-Fi
    By Bradley1928 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-13-2018, 10:53 AM
  3. Device maintenance S9+ Verizon
    By ZOMMBIE1 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-13-2018, 10:28 AM
  4. S9 Keeps dropping Wi-Fi
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 03-13-2018, 09:18 AM
  5. S9 Keeps dropping Wi-Fi
    Last Post: 03-13-2018, 07:23 AM
