1. rjack22's Avatar
    I would like to remove the icon in the notification bar that tells you the percent of battery charge you have left. Its just taking up room. Is there a way to remove it?
    03-13-2018 01:15 PM
  2. evernolasco191's Avatar
    Go to settings. I'm forgetting which specific option it is, but in settings you will be able to customize your notification bar.
    03-13-2018 01:19 PM
  3. ZOMMBIE1's Avatar
    It's under display settings and then status bar.
    03-13-2018 03:21 PM
  4. Rukbat's Avatar
    Or Settings/Battery - you can c heck a box there to display it. Just uncheck it if it's checked. (And make sure you aren't running an app that's doing it. GSam, for example, does it.
    03-13-2018 05:24 PM
  1. Apps to use Laying down.
    By James Bricknell in forum Daydream View
    Last Post: 04-05-2018, 01:46 PM
  2. Battery life
    By o4liberty in forum Google Pixelbook
    Last Post: 03-16-2018, 02:10 AM
  3. what is best way to imitate Samsung's phone on my Motorola Moto X2 2nd gen?
    By Matthew Dunnington in forum Samsung Galaxy S9 & S9+
    Last Post: 03-13-2018, 04:08 PM
  4. In safe mode i can start app from home screen
    By holgitrading in forum Android Security Talk
    Last Post: 03-13-2018, 02:36 PM
  5. Why I see 404 error on my LG G4 when trying to open Google play
    Last Post: 03-13-2018, 01:34 PM
