1. tygerrr's Avatar
    How long can one expect it will take for Samsung to release an update that will fix the horrible video stabilization with the S9 and S9+? I was pretty certain that I was going to be switching from iPhone X to S9+ but then I saw the video stabilization in the Samsung....absolutely unusable video in my opinion and frankly if I were Samsung I would be embarrassed. And no AF at higher FPS? and 5 minutes max? Second guessing my decision to go with the S9+
    With all that said, I'm pretty confident they will push out a fix....but how long does something like that typically take from Samsung?
    03-13-2018 03:07 PM
  2. SpookDroid's Avatar
    Limitation to 4k recording has been there since their first device so that's not going away soon
    03-13-2018 03:14 PM
  3. ZOMMBIE1's Avatar
    I'm not having any video stabilization issues. It's actually quite good. what issues are you having?
    03-13-2018 03:16 PM
  4. waveuk's Avatar
    Can you please share one of your examples?
    I do not see any issue with mine.
    03-13-2018 03:38 PM
  5. RandomGuy Yo's Avatar
    Probably referring to something some know it all YouTuber said. In fact I think I seen the video, it had aggressive stabilization and tries to correct itself
    03-13-2018 04:11 PM
  6. tygerrr's Avatar
    I haven't seen a youtube video review that DOES NOT have the janky and aggressive stabilization. And there are plenty of reviews out that highlight the exact same issue...as well as overexposure and extremely soft and mushy front camera.
    03-13-2018 04:41 PM
  7. ZOMMBIE1's Avatar
    And a lot of YouTubers just have review units not running the latest software. Not saying it isn't a issue, just going off what my experience is with mine. It's not an issue with my S9+
    03-13-2018 05:59 PM
  8. SpookDroid's Avatar
    Ah, review videos. Yeah, posts like these should state that they haven't actually used the phone. That being said, Sammy video stabilization has always been aggressive when using the digital one, and to some, that's unusable. For normal scenarios, however, it's usually a non-issue. But then again, reviewers don't use 'normal scenarios', do they? :P
    03-13-2018 06:03 PM
  9. tygerrr's Avatar
    I would say taking a walk around a neighborhood park or around town is a normal scenario.
    I've yet to see any youtube video from the S9 that doesn't have the issue. The front camera doesn't seem to have the stabilization problem, but it does crop in quite a bit when stabilized.
    03-13-2018 06:10 PM
  10. tygerrr's Avatar
    Can you upload a 4k example to include panning?
    03-13-2018 06:11 PM
  11. Marcin S2's Avatar
    Hello,
    I've also have issues with video stabilization in UHD mode. It's super aggressive and creates artifacts which makes the video complete disaster. My friend watching movies from S9 are basically laughing at them.. looks like the phone is not ready for 4k. When I switch the stabilization off.. the artifacts are gone.. but also the stabilization..
    I've raised this issue to Samsung and they are investigating a video sample..
    04-05-2018 06:58 AM
  12. Gipson Hc's Avatar
    This is my example of this issue I also have. It's in UHD 30fps with EIS on only.
    06-02-2018 04:54 AM
  1. Verizon S9+ Unable to set individual SMS notification tones
    By Vinny Fuori in forum Samsung Galaxy S9 & S9+
    Last Post: 09-07-2018, 03:13 PM
  2. WhatsApp For Desktop (Windows 10)
    By tb75252 in forum WhatsApp for Android
    Last Post: 03-13-2018, 08:50 PM
  3. How do I get to clip board pn LG phone?
    Last Post: 03-13-2018, 05:40 PM
  4. How do i delete voicemail s8
    Last Post: 03-13-2018, 05:22 PM
  5. Replies: 1
    Last Post: 03-13-2018, 05:21 PM
