1. Malnoth's Avatar
    I just received my Galaxy S9+ and noticed that the left side has the same light leak issue that the s8 and note 8 had.
    Example from a note 8:
    S9+ light leakage from edges-269548d1506376561t-note-8-has-physical-problem-light-leakage-edges-fullsizeoutput_21a.jpg
    https://forums.androidcentral.com/sa...age-edges.html
    Does anyone else with an S9 have the same issue?
    Is it worth trying to return for another one?
    Thanks!
    03-14-2018 11:07 PM
  2. 05GT's Avatar
    I saw the same thing on every demo model I picked up.
    Malnoth likes this.
    03-16-2018 07:37 AM
  3. akira ambient's Avatar
    I have 2 units and both have it. on has it along the left edge as yours does, and the other only at the top.
    03-16-2018 07:26 PM
  4. 05GT's Avatar
    I still bit the bullet and bought a Coral Blue S9+. I guess I got lucky as it has the slightest hint of light peeking through when the screen is SUPER bright. Otherwise, it's hardly noticeable.
    03-20-2018 08:28 AM
  5. Insomnia NineThree's Avatar
    Sorry for last post I f'd up first time here. I'm glad I'm not the only one with this issue I just noticed it! I never noticed it on my note 8 but I have light coming from the edges and the top right above the front camera. I'm really picky about crap like this but I think I'll wait for the new iPhone or the new note for a replacement.
    04-10-2018 08:46 PM
  6. Garz's Avatar
    Just saw this thread and checked my s9+. No light leakage. I turned off the lights to have darkness to make sure.
    04-15-2018 10:12 PM
  7. flyingkytez's Avatar
Name:	269548d1506376561t-note-8-has-physical-problem-light-leakage-edges-fullsizeoutput_21a.jpg
    Thanks!
    I don't see anything. The consequences of having a curved screen the display gets distorted.
    04-15-2018 11:58 PM
  8. Ryza321's Avatar
    I have it, but is a display thing, it's not a issue
    04-16-2018 01:09 AM
  9. akin_t's Avatar
    Seriously? It's called refraction ...
    04-16-2018 11:24 AM
  10. Victor Bayas's Avatar
    Wasn't it a "feature" of curved screens?
    04-25-2018 03:44 PM
  11. strikeIII's Avatar
    This is not refraction. This is simply just the black boarders underneath the screen are not painted all the way to the edge.
    04-26-2018 09:37 AM
  1. Share your S9/S9+ Homescreen!
    By sleepnclass in forum Samsung Galaxy S9 & S9+
    Last Post: 08-05-2020, 01:43 AM
  2. Are you prevented from taking screenshot of bank app?
    By chocokat in forum Samsung Galaxy Note 8
    Last Post: 06-09-2019, 07:03 PM
  3. How to turn wifi calling on galaxy s9
    Last Post: 03-14-2018, 11:16 PM
  4. Samsung Galaxy S9 always on display ODD behavior
    By ThrowinRocks in forum Samsung Galaxy S9 & S9+
    Last Post: 03-14-2018, 11:03 PM
  5. Samsung S9 How do I change a thread option in the messages app
    Last Post: 03-14-2018, 09:12 PM
