1. Hirak Sarkar's Avatar
    Hello people!
    You know my query
    Header tells everything!
    03-15-2018 09:39 AM
  2. bhatech's Avatar
    How many headphones you have? I have many Bluetooth devices connected to my phone and honestly I don't know if there is a limit. How to connect? You put the Bluetooth device in pairing mode (refer to that device manual) and go to Bluetooth settings on the phone to pair it up.
    Once you pair the phone automatically connects to the last connected Bluetooth device from then on. You can also manually connect to thm from the Bluetooth settings.
    03-15-2018 09:49 AM
  3. N4Newbie's Avatar
    But, if you mean, how many headphones can you connect and listen through *simultaneously*, then the answer is exactly one.
    Only option for simultaneous output would be to add a Bluetooth splitter. But even those will usually handle a maximum of two output devices.
    03-15-2018 01:26 PM
  4. gazuga6176's Avatar
    go to settings>connections>bluetooth, hit the 3 dots in the upper right corner and select dual audio. you can pair 2 audio devices at once.
    missrae2004 likes this.
    03-15-2018 01:35 PM
  5. Hirak Sarkar's Avatar
    So, I can connect 2 headphones at once. That means if I'm watching a movie, I can share the audio with just one friend.
    What's that Bluetooth splitting thing BTW?
    03-16-2018 11:28 AM
  6. gazuga6176's Avatar
    correct. bluetooth splitters are basically a device that receives your services bluetooth signal, then splits the signal via headphone jacks.
    03-16-2018 08:53 PM
  7. Hirak Sarkar's Avatar
    Thanks for helping
    03-17-2018 06:55 AM
  8. D13H4RD2L1V3's Avatar
    The S9 has a feature called Dual Audio, which allows 2 BT audio devices to be paired at the same time with audio playing through both.
    Go to Settings, Connections, Bluetooth, switch it on if it isn't already, tap the 3 dots on the top right and select the option.
    03-17-2018 06:58 AM
  9. Hirak Sarkar's Avatar
    Just want to know, is this dual audio feature is specific to this particular smartphone? Or any smartphone with bt 5 or above have this same feature in common?
    03-17-2018 07:01 AM
  10. D13H4RD2L1V3's Avatar
    As far as I know, it's on the S8, Note8 and S9.
    03-17-2018 07:08 AM
  11. N4Newbie's Avatar
    I've owned most every Nexus and Pixel phone, including my current device Pixel 2 XL. None of them have offered dual audio output.
    It appears to be a Samsung thing.
    03-17-2018 08:31 AM
  12. Hirak Sarkar's Avatar
    Once I read somewhere that in some latest Motorola phones one can connect upto 5 bt headphones. I can be wrong though
    03-19-2018 08:29 AM
  13. Jaycemiskel's Avatar
    That's not simultaneously though. You'll only hear audio out of one of the devices at once.
    03-19-2018 09:13 AM
  14. Hirak Sarkar's Avatar
    Oh, I see. Then it's completely a Samsung thing
    03-20-2018 10:42 AM
  1. How do i stop my samsung saving photos to picture gallery?
    Last Post: 03-21-2018, 10:39 PM
  2. Replies: 2
    Last Post: 03-15-2018, 04:05 PM
  3. A pop up site opens in chrome after i downloaded and installed an apk file
    Last Post: 03-15-2018, 10:06 AM
  4. Will a S7 edge unlocked sim card work with an unlocked s9+
    Last Post: 03-15-2018, 09:42 AM
  5. I have an android and i get an error code 96
    Last Post: 03-15-2018, 09:00 AM
