04-08-2018 08:19 AM
88 123 ...
tools
  1. djdonnyk's Avatar
    I took my phone off charger at 6:30 AM and back on charger at 10PM, so this is what apps are running the last 2 days. I'm running Bluetooth playing Iheart radio all day, some web browsing, a few phone calls and about 1 hour of playing billiards. I was good all day on battery, still had about 10% left when I put it on the charger. I'm impressed with the battery so far!
    SpookDroid, SR45, KP8819 and 1 others like this.
    03-15-2018 11:20 AM
  2. SpookDroid's Avatar
    Same here, getting pretty much the same battery as with the Note 8. Not sure why those reviewers complaining about battery life had such crappy one, but I'm not seeing that.
    SR45, Rose4uKY and acles003 like this.
    03-15-2018 12:31 PM
  3. Jtshurtleff's Avatar
    People love to commiserate together. I have been pleasantly surprised by battery life, better than the iPhone X in everything but standby and as good as my Pixel 2 XL.
    03-15-2018 12:35 PM
  4. Morty2264's Avatar
    So glad the battery is working well for you all!
    03-15-2018 01:05 PM
  5. rushmore's Avatar
    It would be real handy for folks to state which chipset they have. 845 or 9810.
    geraldem and Morty2264 like this.
    03-15-2018 01:49 PM
  6. SpookDroid's Avatar
    T-Mobile version here, so Qualcomm
    03-15-2018 02:18 PM
  7. Lecrae116's Avatar
    I'm on sprint. Very light usage and still 58% left. Do you think this battery life can improve. If so help would be appreciated. Auto brightness on,AOD off.
    03-19-2018 09:43 PM
  8. rushmore's Avatar
    My 9+ 845 battery life is the same so far as my 8+. Happy.
    03-19-2018 10:08 PM
  9. Allen_Jolynn0's Avatar
    I have the S8+ and wife has s8. My s8+ last longer than hers. Lol
    03-20-2018 06:32 AM
  10. Frozen Corpse's Avatar
    Here's my stats...
    AustinTech likes this.
    03-20-2018 07:41 AM
  11. irock1985's Avatar
    TMobile 845 chipset... With fresh install of all apps nothing restored. Why fresh install you ask check the video below
    03-20-2018 05:34 PM
  12. eduardmc's Avatar
    Im getting 6hour+ sot on everycharge, in my 18 hour days, this is with normal live wallpaper and high performance on. Im not even trying to maximize battery cause this is good enough for me.
    03-20-2018 05:54 PM
  13. gazuga6176's Avatar
    I'm enjoying epic battery life right now. hope it stays this way. s9+ 845 att
    03-20-2018 08:24 PM
  14. Jbartu's Avatar
    Verizon 845 and so far it seems better than my Note 8.
    Attached Thumbnails S9+ battery life-screenshot_20180320-221614_settings.jpg
    Rose4uKY likes this.
    03-20-2018 10:18 PM
  15. jlczl's Avatar
    It won’t. It never has and I don’t expect that’ll change. My S9 is great now but so was my Note 8 before that and S8+ before that. Give it a month or two and you’ll see it’s time to reset and start again or you’ll begin to see more lag and your battery dying sooner than it had been. No hate just truth.
    03-20-2018 10:38 PM
  16. vwite's Avatar
    It won’t. It never has and I don’t expect that’ll change. My S9 is great now but so was my Note 8 before that and S8+ before that. Give it a month or two and you’ll see it’s time to reset and start again or you’ll begin to see more lag and your battery dying sooner than it had been. No hate just truth.https://uploads.tapatalk-cdn.com/201...e8cf9e7be6.jpg
    You're probably right
    03-20-2018 10:48 PM
  17. MooMooPrincess's Avatar
    I FINALLY have barely tolerable sot
    03-20-2018 11:48 PM
  18. Jaycemiskel's Avatar
    @MooMooPrincess Lol that's barely tolerable for you? You must be getting some awesome life on other phones.
    03-21-2018 09:43 AM
  19. MooMooPrincess's Avatar
    7+ hrs before 20% is what I consider good. That's what I'm accustomed to lol, my 2xl and n8 have spoiled me.
    03-21-2018 10:27 AM
  20. gazuga6176's Avatar
    oh I know. I was lucky to get through the day on my s7e. the last sammy I had decent battery on throughout the life of the phone was the note 4. that thing was a beast.
    jlczl likes this.
    03-21-2018 12:02 PM
  21. rushmore's Avatar
    My 8+ 835 version continued to have great battery life for the year I had or it, so disagree. There seems no technical rationale for the assertion it would not. I have not had that experience with any Android phone. G1, Incredible, Droid 2, Razr, S4, Note 4, MX Pure, S7, Note 7, S8, S8+. None. Added: Use my S8 still for Gear VR, which is a battery drainer. Still holds a charge well.
    03-21-2018 01:23 PM
  22. rimz808's Avatar
    how long did you guys use your phone till you started to see battery improvement? this is my second Samsung phone.. had the note 7 till it was recalled and never did had much luck with battery life on that device and also experienceing the same battery life on my s9 plus.
    This is my 4th day with it and I'm running out of battery within about 12 hours. I always have to charge it by night time. what also is the same as before is that I usually go from 100% to about 95% in just about 45 mins in the morning after taking it off the charger. is that normal?
    Should I drain and charge the battery a few times till I start seeing an improvement?
    03-21-2018 01:36 PM
  23. tadpoles's Avatar
    The seems very good so far.
    03-21-2018 02:58 PM
  24. Ryano89's Avatar
    Should be much better battery life then the note 8. Bigger battery(300 more mah), newer more efficient processor, and Oreo. I would assume it should be getting significantly better battery life than a Note 8, although I don't own a 9+ yet so I can't compare.
    03-21-2018 04:05 PM
  25. SpookDroid's Avatar
    Well, after 'settling in' I am getting better battery life than with the Note now. I do miss the S-Pen though.
    03-21-2018 05:05 PM
88 123 ...
  1. I have no sound with texts on galaxie s9
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 09-24-2018, 08:49 AM
  2. Schedule messages from a Samsung Galaxy s9+
    Last Post: 09-16-2018, 07:34 AM
  3. How many bt headphones can I connect to one S9/S9+? And How?
    By Hirak Sarkar in forum Samsung Galaxy S9 & S9+
    Last Post: 03-20-2018, 10:42 AM
  4. S9+ and notifications
    By Phillip Lehmkuhl in forum Samsung Galaxy S9 & S9+
    Last Post: 03-18-2018, 06:07 AM
  5. Battery Life Of s9 +
    By Harsh Agarwal3 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-15-2018, 11:14 AM
