1. Victor Hernandez Jr's Avatar
    This was a problem I was having with the Note 8 and for some reason with the S9 plus I'm having the same problem it constantly drops from fast charge to Cable charge I have changed wires change Outlets with the same problem anybody else?
    03-15-2018 08:44 PM
  2. SpookDroid's Avatar
    Are you using the supplied fast charger and cable?
    03-15-2018 09:16 PM
  3. stillintheD's Avatar
    I agree with SpookDrois. I have only seen this issue if you are not using the OEM cable and fast charger. Not all chargers/cables meet the specifications for quick/fast charging. On my Pixel 2 XL, it NEVER shows "FAST" charge unless I am using the OEM charger. I can use my other cables. But not the charger.
    03-16-2018 02:47 AM
  1. Android auto issue??
    By ghaleon92 in forum Samsung Galaxy S9 & S9+
    Last Post: 07-11-2019, 07:18 PM
  2. Galaxy S9+ Black Crush and Gradient Banding Issues
    By Stocklone in forum Samsung Galaxy S9 & S9+
    Last Post: 09-10-2018, 02:13 PM
  3. Gps issues
    Last Post: 03-15-2018, 03:10 PM
  4. Re: Firmware upgrade Encountered an Issue
    Last Post: 03-15-2018, 02:54 PM
  5. Strange issue with fingerprint sensor on two different SIM cards
    By kdvw2608@gmail.com in forum Samsung Galaxy S8 & S8+
    Last Post: 03-15-2018, 09:54 AM
