1. Jesus Delgadillo's Avatar
    I just came from the Note 8 and got my S9+ and went straight to Zagg to get the Elite Glass and the guy tried applying 3 of them and none would stick to the edge! The note 8 version never came out to stores due to issues as well. With that being said, what Glass do y'all recommend that will stick completely to the screen without touch sensitivity issues or dust sticking on the edges. I need one asap cause this is my first phone I'm using without a glass from the moment I buy it.
    03-17-2018 07:20 PM
  2. legin111's Avatar
    Hands down white stone glass. A little expensive but it works really well and with a lot of cases too
    03-17-2018 07:50 PM
  3. 20blks's Avatar
    Galaxy S9 Glass Screen Protector, [Case Friendly] OTAO 3D Curved Dot Matrix Tempered Glass Screen Protector [Tray Installation] for Samsung Galaxy S9 https://www.amazon.com/dp/B079JSXSNK...cUvbUpU6194938
    Just use the sensitivity setting on the phone and you should be Ok. I have one and it's pretty decent. No popping as of yet. Best of all, it's pretty cheap
    03-17-2018 07:50 PM
  4. LJSquishy's Avatar
    Whitestone Dome for sure.
    03-17-2018 08:18 PM
  5. JHBThree's Avatar
    Supposedly there was a hold sale put on these at Verizon. I went in to buy one today, and even though they had a stack of them they couldn’t sell them. They were able to sell the regular S9 ones though, so could just be related to the size of the phone.
    Jesus Delgadillo likes this.
    03-18-2018 02:40 AM
  6. bandofbrothers2112's Avatar
    I gave up on glass type protector shield a while ago for my s8 as they tended to fall away.
    I now use the official Samsung Film type screen protector which comes as a pack of 2 and do not feel overly plastic to the touch.
    sangs likes this.
    03-18-2018 02:45 AM
  7. cactuspete23's Avatar
    Is it just me, or is it a little weird that every phone makes touts how light and then their phone is; And then a lot of us add a case and/or screen protector that adds weight and some thickness... Seems to me like the phone should come "ready to carry" and not need added stuff.
    missmotta likes this.
    03-18-2018 06:59 AM
  8. rjack22's Avatar
    I have Techmatte's amFilm Tempered Glass screen protector on my S9. Also available for the S9+. I am very happy with it! It has been on a week now and nothing has lifted. It sticks. No bubbles either. This protector comes with a applicator guide that makes it foolproof to put on. So easy as the guide does the alignment for you! And it was one of the screen protectors recommended Android Central as one of the top ten.
    Here is a link:
    TechMatte
    03-18-2018 07:42 AM
  9. Squarrow's Avatar
    Zagg recalled the Elites. Get Bodyguardz.
    03-18-2018 08:06 AM
  10. tadpoles's Avatar
    I got my Note 8 Curve Elite from a Zagg store and they installed it. It's perfect as far as I can tell.
    03-18-2018 08:27 AM
  11. D13H4RD2L1V3's Avatar
    Whitestone Dome
    It's super expensive and has a more involved installation process but it works wonders
    03-18-2018 08:38 AM
  12. jlczl's Avatar
    LOL all glass screen protectors will suck for our edge screens. The only difference between those who say theirs is great and the ones who say theirs aren't, is the level of OCD of the user.
    03-18-2018 10:12 AM
  13. Theot's Avatar
    I quit zagg after the regular S7, even with the slight edge on that it wouldn't stick and was terrible.
    03-18-2018 10:36 AM
  14. KP8819's Avatar
    I have a fairly high level of OCD lol
    Found that (if installed correctly) the Whitestone Domed glass is great - touch sensitivity & clarity is like nothing is there. The only thing that let's you know it is there is the cut out for the speaker & camera (that does kinda bother me & shouldn't lol)
    03-18-2018 10:42 AM
  15. daswooski's Avatar
    I have not had great luck with Zagg but i use the OTAO on my S9 and had it on my S8...so far so good...also i have heard many folks are going back to the old style protector and not the glass one and are having more luck...seems like someone will get it right but until then it is either Whitestone, OTAO, old style or just patience until another one comes out, good luck...
    03-18-2018 10:45 AM
  16. jlp0209's Avatar
    Whitestone Dome Glass is the exception. Best screen protector I've ever used. There's no dot matrix and the adhesive is on the whole thing rather than just the edges. It's a liquid install but different than other liquid installs, and the edges don't bubble or raise up at all.
    daswooski likes this.
    03-18-2018 10:45 AM
  17. daswooski's Avatar
    Agreed,i like to upgrade often so being able to get the most for resale is important to me and having no scratches makes a difference, if not for this i would not use a case at all and often do not when i am at my desk....
    03-18-2018 10:48 AM
  18. bhatech's Avatar
    As long as it's not cracked, personally I'll take a little hit on resale value for using it without case and most definitely screen protector (hate them and haven't used in years).
    With Apple, I use the apple upgrade program so never bother about scratches. With Android phones yeah little tricky but generally I price it little lower based on condition and have no problem selling. It's just a trade off for me, use it without a case for a little hit on resale value or get max resale value. Personally, I'm ok
    03-18-2018 10:57 AM
  19. cactuspete23's Avatar
    Vert Cool !
    03-19-2018 05:37 AM
  1. Warning Recording Failed!!
    By TechnicallyTee in forum Samsung Galaxy S9 & S9+
    Last Post: 10-13-2018, 03:25 PM
  2. "Not registered on network" after failed update
    Last Post: 03-15-2018, 05:05 PM
  3. Replies: 1
    Last Post: 03-15-2018, 04:02 PM
  4. Wipe Fingerprint Sensor and try again
    By ja206 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-15-2018, 12:06 PM
  5. Network connection fail label across screen
    By hou33guy in forum Samsung Galaxy Note 8
    Last Post: 03-15-2018, 09:51 AM
