1. Doyle Davis's Avatar
    Has anyone else noticed that media volume sync doesn't seem to be working with Android 8.0? I have a JBL Charge 3 speaker that I know supports volume sync. I previously had an S8+ with Android 7 and volume sync worked fine with the speaker.
    03-18-2018 04:04 PM
  2. bigbaddaveman's Avatar
    It was working for me but I turned it off to try out using multiple audio devices at the same time. Now I can not turn it back on. I am using Samsung Level over headphones which definitely support the feature.
    04-04-2018 10:18 AM
  3. Doyle Davis's Avatar
    Yup, that is the same message I get! Looks like a bug to me. Let me know if you figure it out.
    04-04-2018 12:23 PM
  4. jwcrosby's Avatar
    Has anybody resolved this issue? I'm having the same problem on my Note 9. I know for certain that my devices work with MVS, as it worked with my S8+ and Note 8, but now with my Note 9, the option is greyed out and reports the error that my device must be compatible, which they all are...
    I have read it is a bug on the 9 series with the Android 8/Oreo... Any verification of this... Considering contacting Samsung, not that they'll likely have much to contribute...
    Thank you,
    ~J
    12-03-2018 12:05 PM
  1. Are there any galaxy s9 plus cases that is raised on all 4 sides of the screen?
    By Android Central Question in forum Samsung Galaxy S9 & S9+ Cases & Accessories
    Last Post: 04-08-2018, 03:42 AM
  2. Galaxy S9= keep getting message "WiFI Disconnected" while at home
    Last Post: 03-20-2018, 06:06 PM
  3. Stop SMS sync
    By ja206 in forum Ask a Question
    Last Post: 03-16-2018, 08:34 PM
  4. Cannot get my Outlook calendar to sync with the Samsung calendar
    By JenWilfong in forum Samsung Galaxy S9 & S9+
    Last Post: 03-16-2018, 05:06 PM
  5. Are there any galaxy s9 plus cases that is raised on all 4 sides of the screen?
    Last Post: 03-15-2018, 12:45 PM
