    Does the samsung s9+ have the delay send text messages?
    03-20-2018 08:25 AM
  2. williams448's Avatar
    If you're using stock SMS app, hit the + button next to the text field
    03-20-2018 09:30 AM
  3. hmhecht's Avatar
    I came across this thread while trying to find out the answer as well.
    From what I can see on my new and factory-unlocked SGS9+ the above method only allows scheduling an individual SMS, which can be useful.
    However, my old SGS5 had a feature called "Delay Message Sending" that applied to all SMS / text messages. It gave a user-definable period of time (3, 5, 10, 20, or 30 seconds) where one could cancel a message from being sent, effectively "undoing" the send if you notice something wrong.
    I used that feature all the time and it saved me from many potentially embarrassing moments giving me time to fix auto-incorrect issues and even almost-misdirected texts.
    I can't seem to find this feature on my SGS9+. Anyone know where it is, or can confirm it has been removed? I suspect it is no longer available, which begs the question of WHY Samsung keeps removing such useful features?!?
    Thanks in advance!
    05-11-2018 01:55 PM
  4. 5shonda2's Avatar
    Thanks in advance!
    I just got the Samsung Galaxy S9 and I was looking for the delay send text message feature that I had on the Galaxy S5 and it doesn't seem to be here. I don't know why Samsung would take it away it's very useful. That's why I upgraded to an S9 from my old S5 so I'm very disappointed.
    07-21-2018 12:30 AM
  5. Mooncatt's Avatar
    If you can't find a way to do it in your messaging app (I don't have Samsung phones), look into the Handcent texting app. It's what I use, and it does have a delay send feature like you're wanting.
    As for your last comment, such is the new trend of smartphones. Take away features, charge more for it, and call that progress.
    5shonda2 likes this.
    07-21-2018 02:35 AM
  6. 5shonda2's Avatar
    Hello thanks for the recommendation I got the handcent text app this morning and it seems to do the trick with sending text messages on a delay the Max is 7 seconds. It's unfortunate that it's not a stock feature on the Galaxy S9 but I guess the app will do.
    07-21-2018 11:38 AM
  7. Mooncatt's Avatar
    I didn't realize Handcent had a max setting. I only want mine set for 5 seconds, but I thought it could go much longer. Glad it works for you either way.
    07-21-2018 11:50 AM
  8. waqqas31's Avatar
    Textra supports delayed sending:
    Attached Thumbnails How to set up delay send of text messages on the Samsung S 9+-screenshot_20180722-092555_textra.jpg
    07-22-2018 09:28 AM
  9. THEPRFCT10's Avatar
    Textra works great you can even select the exact time at which you want the message to be sent
    07-23-2018 01:33 AM
  10. ABOSWORTH007's Avatar
    It's sad that Samsung keeps stripping features from the messaging app. I really liked delayed sending as well. I know you can do this on third party texting apps but then you can't send advanced messages (I'm with AT&T) so that pretty much bombs out any other third party messaging app. If the stock messaging app had delayed sending and the ability to set wallpapers and customize the bubbles, like it used to, I'd be completely happy with stock app. I like using advanced messaging features with my wife so we can get read receipts, see when the other is typing and send larger picture and video messages.
    07-23-2018 08:19 AM
  1. White on white messages
    Last Post: 03-31-2018, 08:50 AM
  2. Why won't my Samsung keyboard ever come up?
    Last Post: 03-21-2018, 03:59 PM
  3. Can't convert .Avi to play on Moto e4
    By esjayy in forum Moto E4 & E4 Plus
    Last Post: 03-16-2018, 05:07 PM
  4. Unicorn adblocker for Samsung internet
    By 30k in forum Ask a Question
    Last Post: 03-15-2018, 05:56 PM
  5. Droibox MXG blue flashing led won't turn on.
    Last Post: 03-15-2018, 04:01 PM
