    If it does, how do you turn it on?
    03-21-2018 04:57 PM
  2. Kristofer1276's Avatar
    If so, how do you turn it on and adjust settings
    03-21-2018 06:54 PM
  3. belodion's Avatar
    [Threads merged.]
    03-21-2018 06:59 PM
  4. accapro's Avatar
    It's in settings under display.
    03-21-2018 08:13 PM
  5. claykin's Avatar
    I believe that was a feature of the S7 edge which had a larger edge. S9+ edge isn't large enough to display time. It's good for notifications and making it ridiculously difficult to apply a screen protector.
    03-21-2018 09:01 PM
  6. strikeIII's Avatar
    It's actually part of the Always On Display. You can enable the edge clock through there.
    03-21-2018 09:15 PM
  7. Abbers727's Avatar
    I couldn't find it.
    03-21-2018 10:43 PM
  8. Devhux's Avatar
    Not on the S9
    03-21-2018 11:37 PM
  9. strikeIII's Avatar
    So is it just on the S9+ model? Cuz It's available on mine. AT&T version.
    03-21-2018 11:43 PM
  10. strikeIII's Avatar
    I couldn't find it.
    Not on the S9
    03-21-2018 11:44 PM
  11. claykin's Avatar
    It's there on my s9+. In the clockstyle menu. Second to end of list. I'm on TMo.
    03-22-2018 12:06 AM
  12. Chris_c81's Avatar
    It doesn't function like the S7 Edge did. You set the AOD to whatever you wanted, but seperately during a time window, you could set the edge clock to display instead. Hence "night clock".
    03-22-2018 12:52 AM
  13. Abbers727's Avatar
    I found it. Kind of sucks you can't set it on a timer of when to turn off the night clock now.
    03-22-2018 01:06 AM
  14. strikeIII's Avatar
    Yeah all that was gone after the S7 Edge.
    03-22-2018 07:10 AM
  1. Galaxy S9= keep getting message "WiFI Disconnected" while at home
    Last Post: 03-20-2018, 06:06 PM
  2. Compare 9 plus to LG V30
    By kb0uy in forum Samsung Galaxy S9 & S9+
    Last Post: 03-18-2018, 09:44 PM
  3. Replies: 5
    Last Post: 03-18-2018, 10:46 AM
  4. Cannot get my Outlook calendar to sync with the Samsung calendar
    By JenWilfong in forum Samsung Galaxy S9 & S9+
    Last Post: 03-16-2018, 05:06 PM
  5. Why does my lightning charger work for my cell phone but not my tablet?
    Last Post: 03-15-2018, 04:47 PM
