    When I go thru the process it appears to want to 'Wipe' my watch before it can connect to my new S9+
    I do not want to wipe the watch as I have Watchfaces and music and such that I do not want to have to go thru the process of re-syncing.
    Am I doing it wrong.
    Thanks for any help.
    03-22-2018 06:29 PM
  2. 05GT's Avatar
    Required in order to connect to new device. Should be asked if you want to restore once you get set back up.
    03-22-2018 06:34 PM
  3. strikeIII's Avatar
    Yeah everytime you set up your Gear S3 on a new device it has to wipe it. If you had the backup option turned on with your previous device it should restore all your watchfaces.
    03-22-2018 06:41 PM
  4. CaptivateRookie's Avatar
    It appears at some point the backup stopped working. So the only backup I have is from Feb of 2017... so not good. I need a backup before I reset this watch.
    03-22-2018 08:34 PM
  5. CaptivateRookie's Avatar
    Just laughed at my own name... CaptivateRookie... I have teuely run thru the Galaxy line of phones with my latest upgrade to the S9+ today...
    03-22-2018 08:35 PM
  6. Rose4uKY's Avatar
    So if I'm getting an S9 plus soon and I have a gear S3 I need to make sure backup option is turned on where on my phone that I have now or on the watch
    03-25-2018 02:10 AM
  1. Why do I sometimes get checking server message when trying to text?
    Last Post: 05-07-2018, 07:23 PM
  2. Replies: 2
    Last Post: 03-23-2018, 09:22 AM
  3. My pull down bar disapeared and my background goes black
    Last Post: 03-22-2018, 09:52 PM
  4. refurbished galaxy note came with factory binary mode still up
    Last Post: 03-22-2018, 05:41 PM
  5. S9 plus unboxing
    Last Post: 03-22-2018, 05:16 PM
