Is anyone using the whitestone dome glass screen protector on their S9+, if so what case are you using? looked at a few videos online but looks like there isnt a good comparison yet. Obviously looking for a case that wont lift the screen protector over time.
I watched the videos on case compatibility for the S8 plus and Note 8. There seems to be mixed opinions on some cases. I'm using a Sup case Unicorn Beetle Pro for now because of the built in screen protector until I see come compatability reviews. I don't want to mess up my Whitestone dome considering the price and time to install.
FWIW, the Unicorn Beetle Pro is a great case, but the built in protector is plastic and leaves lots of smudges and fingerprints. Screen sensitivity seems to be pretty good though.
thanks Im using that as well, same concern on the case compatibility, of the videos I have seen, one says case X is compatible, then next video they say Case X is not compatible. SO waiting to see as well. On my S7 Edge had the otterbox defender, which did a great job protecting the phone that is still looked brand new when I took it out of the case when I got the s9+, but the screen protector wasnt all that great at times. The Supcase screen protector does seem to do a much better job with touch, but not sure if it is as great at shock protection.
I bought the Whitestone protectors thinking I wanted to go that route since the touch on the Otterbox was at times not great. But looking for a case that works, as I dont want it to lift after a few days. I am sure it will show fingerprints as well, that isnt something that is so concerning to me. Ideally like to get a case that works with the whitestone so can see the phone, as my wife has the lilac version and like it.
I was thinking about the Spigen Clear Hybrid case, that one appears to be compatible from two separate reviews so far.
