1. wrmoore47's Avatar
    I hope this is something simple, but under Settings>Sounds and vibration>Volume>Ringtone I see a speaker with a slash through it, and it doesn't change when I tap it. Consequently, I have no ringtones. Sound in the quick settings is on. Vibration works fine. What have I done to cause this? This is a Verizon S9+ just bought yesterday. I've run the system update that I got today, but that didn't help.
    Thanks!
    Randy
    03-24-2018 04:01 PM
  2. claykin's Avatar
    Have you tried the volume up key on side of phone? Or drag the onscreen bar?
    03-24-2018 06:30 PM
  3. wrmoore47's Avatar
    Those have no effect.
    03-24-2018 07:18 PM
  4. claykin's Avatar
    Do you have ring tones to choose from? You should have the factory default list. About 35 or so. If not, consider doing a factory reset.
    03-24-2018 07:56 PM
  5. wrmoore47's Avatar
    Yes, I have the standard ones plus several of my own that came over with SmartSwitch.
    03-24-2018 09:00 PM
  6. dbollman423's Avatar
    i have an S7 and see a speaker, but touching it does nothing. You have to slide the ball to the right.
    03-24-2018 09:14 PM
  7. wrmoore47's Avatar
    If you mean the slider, one does not show. Only the speaker with the line through it.
    03-24-2018 09:25 PM
  8. wrmoore47's Avatar
    Powered my gs9+ off over night, and today the ringtone works fine. Yesterday I restarted and power cycled the phone several times with no change, so I have no idea what happened!?!? Hope it stays fixed.
    11B1P likes this.
    03-25-2018 07:40 AM
  9. wrmoore47's Avatar
    Well, it didn't last long. Ringtone is not working again! Haven't changed a thing! I saw several posts about this on the Pixel 2, but not on the Galaxy phones. Back to Verizon store tomorrow!
    03-25-2018 12:20 PM
  10. wrmoore47's Avatar
    Here's the Sound setting screen.
    GS9+ Ringtone volume is stuck on off-screenshot_20180325-121608_settings.jpg
    03-25-2018 12:33 PM
  11. krisqz's Avatar
    Have you scheduled 'do not disturb' maybe?
    03-25-2018 01:26 PM
  12. wrmoore47's Avatar
    Yes, but only at night.Attachment 281552GS9+ Ringtone volume is stuck on off-screenshot_20180325-133315_settings.jpg
    03-25-2018 01:35 PM
  13. wrmoore47's Avatar
    Another clue: when I go to pick a Ringtone from the list of them, they do not play when picked as they normally would.
    03-25-2018 01:40 PM
  14. wrmoore47's Avatar
    Turned off Do Not Disturb all together, power cycled the phone, still no Ringtone.
    03-25-2018 03:58 PM
  15. lucianus_luciferus's Avatar
    Maybe you have an app that is disabling ringtones
    Or try Settings, general management, reset, reset settings.
    03-25-2018 04:12 PM
  16. wrmoore47's Avatar
    THANK YOU! Didn't know I could reset just settings. Did that, and started redoing my settings while watching the Sound>Volume>Ringtone. Discovered that turning on Bluetooth shut down Ringtone. That led me to look into my Moto 360 watch settings. Somehow in setting up my new phone, I had to system reset the watch (cant remember why), apparently that caused the watch setting to mute the phone to be turned on, I guess by default. THAT WAS THE PROBLEM! Long ago I turned off that option on the watch and had forgotten it was there.
    THANKS so much for the help!!
    Randy
    03-25-2018 04:55 PM
  17. Ramer84015's Avatar
    Randy
    Just FYI, anytime you get a new phone you have to reset your smartwatch because it's linked to your old phone.
    03-25-2018 05:09 PM
  1. turning off auto-play videos in Gallery app
    Last Post: 01-15-2019, 05:20 PM
  2. AT&T branded s8 plus on cricket. Will I still receive Oreo update?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-25-2018, 07:51 PM
  3. mediaset and shove play my phone on TV mediaset and shove play my phone on
    Last Post: 03-24-2018, 03:17 PM
  4. AT&T branded s8 plus on cricket. Will I still receive Oreo update?
    Last Post: 03-24-2018, 03:09 PM
  5. DND turns on when connected to Android Auto
    Last Post: 03-24-2018, 03:04 PM
