    after putting on the tampered glass, the screen seem to be less responsive. I need to press on the screen instead of light tought??? can someone help please. thanks
    03-25-2018 10:30 PM
  2. jeetu4444's Avatar
    u have installed non compatible glass on your phone...try and find full glue tempered glass for your phone
    03-26-2018 06:04 AM
  3. ZOMMBIE1's Avatar
    Have you tried turning on touch sensitivity? Under advanced features.
    03-26-2018 06:11 AM
  4. rushmore's Avatar
    I had the problem with the 8+ and also did not like the adhesion on the curves, since with a case was problematic. Ditched the protector and no scratches carrying in front pocket for a year.
    03-26-2018 07:59 AM
  5. lucianus_luciferus's Avatar
    Settings, display, navigation bar, hard press home button and adjust pressure
    03-26-2018 03:21 PM
  6. jnichols16's Avatar
    ZOMMBIE1,
    I realize this thread is five months old. But I still wanted to express my thanks.
    My brand new Galaxy Note 9 needed very hard presses all down the left side. Sprint told me the case needed breaking in.
    I turned on "Touch Sensitivity", now it works great.
    Thanks very much.
    08-31-2018 07:17 PM
  1. Galaxy S9 + and Samsung series 7 not screen mirroring
    Last Post: 03-26-2018, 01:14 PM
  2. navigation bar on S9 not working.
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 03-20-2018, 10:51 PM
  3. S8+ No Nav Bar Buttons
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-18-2018, 11:02 PM
  4. Disappeared buttons on navigation bar
    Last Post: 03-17-2018, 04:40 PM
