1. LazyLightning's Avatar
    I'm not sure what it does that Google assistant does not do? Maybe you all have reasons for using it, would love to know your thoughts
    03-29-2018 01:32 AM
  2. UdiBerry's Avatar
    Bixby is quite powerful in controlling every aspect of your phone. I'm using it all the time alongside Google assistant.
    Here's a video that shows some of Bixby's capabilities:
    djrakowski likes this.
    03-29-2018 02:10 AM
  3. amyf27's Avatar
    I do use Bixxy. I wanted to setup Google Assistant as well, but it seems grated out for some reason.
    03-29-2018 03:49 AM
  4. DamianP's Avatar
    I've tried it a few times and didn't find much use and more importantly hate hitting that button by mistake. Disabled for me .
    03-29-2018 08:16 AM
  5. Devhux's Avatar
    I like being able to adjust settings easily. I did disable the short press of the Bixby button though and remapped it to Volume Down (I was always pressing the button when wanting to lower volume or take a screen shot).
    Long press still lets me talk to Bixby though.
    03-29-2018 08:20 AM
  6. rjack22's Avatar
    How did you remap the Bixby button to something else? I thought that couldn't be done?
    03-29-2018 08:40 AM
  7. ZOMMBIE1's Avatar
    I'm using the stock message and keyboard and Bixby is actually really good at reading and replying to messages by voice for me. Gets to phone settings better than google assistant also
    amyf27 likes this.
    03-29-2018 09:00 AM
  8. amyf27's Avatar
    I use Bixby often to start up my bluetooth and map for driving. Also for screen brightness adjustment etc.
    ZOMMBIE1 likes this.
    03-29-2018 09:06 AM
  9. Devhux's Avatar
    I'm using this app. There's a slight delay, but for my needs it works just fine.
    https://play.google.com/store/apps/d...orks.bxactions
    03-29-2018 09:16 AM
  10. qz0xr3's Avatar
    Thanks for sharing this. I hadn't taken the time yet to familiarize myself with Bixby.
    03-29-2018 10:41 AM
  11. cst516's Avatar
    I also use it all the time. I use it more than the Google assistant. I have several mulit actions set up so I just say one thing and it completrs several action. I really like having the dedicated button although I do unintentionally hit it sometimes.
    03-29-2018 01:19 PM
  12. rushmore's Avatar
    This. Disabled since too easy to press.
    03-29-2018 02:24 PM
  13. Almeuit's Avatar
    I don't have a Samsung phone at the moment but when I did I didn't use it. That would be the case if I had my S9+ as well.
    03-29-2018 02:26 PM
  14. joemontana57's Avatar
    Hit the button by mistake several times. Disabled the button. I've used bixby voice a few times, it's failed each time. So no, I don't use bixby.
    03-29-2018 10:07 PM
  15. Emily 1's Avatar
    I have used the speech to text on the stock keyboard with it, and that is quite good. It was matching me pretty spot on. Otherwise I haven't used Bixby at all, but I am curious about trying to set up some of the command actions with it. I have never accidentally triggered Bixby by the button, but I have been using a pretty thick case that requires firm button pushes.
    04-03-2018 09:15 AM
  16. fgol's Avatar
    I started trying to use Bixby to send texts. Why in the world does it send texts to the contact's work phone number when there's also a mobile number listed? It seems to pick the first number in the contract entry no matter how hard I try to get it to send to the mobile number. It's ponderous that it doesn't default to the mobile number.
    07-26-2019 08:07 PM
  17. lucianus_luciferus's Avatar
    You can chose what number to use via voice command like this: text Mike on mobile.
    Or if you save his mobile number as Home then just say: text Mike on home.
    You can change the default number for a contact by long pressing on it and tapping on set as default.
    07-27-2019 06:41 AM
  18. joeldf's Avatar
    I don't use it.
    Don't really see the point of using any "assistant" app, really.
    Not really keen on talking out loud at my things. Prefer to do that with actual people.
    My wife did buy an Amazon Echo last Christmas. The only thing I've asked it is "why are my dogs weird?"
    It said it didn't "know that one".
    I don't know either, sister.
    amyf27 likes this.
    07-29-2019 06:07 PM
  1. Anyone else having Verizon's Message+ freeze up on their Pixel 2 XL?
    By Hanko in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 03-31-2018, 07:39 PM
  2. Anyone Have Experience Rural Colorado, N.M. and Wyoming?
    By Climb14er in forum General Carrier Discussion
    Last Post: 03-29-2018, 02:14 AM
  3. Does anyone recognize this Samsung ringtone?
    Last Post: 03-29-2018, 12:12 AM
  4. Bixby setting wrong alarm time
    By Taylor Rowe in forum Ask a Question
    Last Post: 03-28-2018, 04:38 PM
  5. what is the black circle with a message in the center used for?
    Last Post: 03-28-2018, 03:45 PM
