1. Shaqeer Khan's Avatar
    I have the S9 Plus with a Spigen Liquid Air case on and i'm wondering is the case compatible with with Whitestone Dome Glass? i'm worried if the case would lift up the glass.
    04-01-2018 12:42 PM
  2. pdrules's Avatar
    looks like no.. check out what it says at around 3 minutes into the vid....i have i have an otterbox case that says no go but i still ordered the whitestone and see if i can modify it
    04-02-2018 10:28 AM
  1. my samsung note 8 is supposed to be a 64GB but says its only 16GB,
    Last Post: 08-26-2018, 03:51 PM
  2. Need my phone on englishmy
    Last Post: 04-01-2018, 06:02 PM
  3. why i am not receving calls on my device
    Last Post: 04-01-2018, 06:01 PM
  4. "Ok google" function not working on my s8?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-01-2018, 03:49 PM
  5. Why is my phone showing google app not working
    Last Post: 04-01-2018, 01:32 PM
