1. rimz808's Avatar
    Just installed the WhiteStone Dome screen protector on my S9+ and it is looking and feeling great.
    Now i'm curious what others do with the UV light? Tanning your hand? sterilize your phone with it?
    Just wondering what good uses can be done with it
    04-02-2018 05:47 PM
  2. rimz808's Avatar
    Any good uses for it?
    04-03-2018 05:12 PM
  3. andrew_ackley's Avatar
    You can use it to get a tan maybe?
    04-09-2018 09:57 PM
  4. CKwik240's Avatar
    Hard to say without knowing it's UV spectrum range. I suspect it likely emits at least some part of the UVA spectrum. I designed and built a light box years ago that my friend needed to cure silk screen emulsion and it required a specific range of UV light to work properly. I'm not sure if different UV sensitive chemicals use similar spectrum or not.
    I'd at least keep it in case you break the protector as they do sell replacement screen protectors without the light for a bit less.
    04-10-2018 02:34 PM
  5. aapold's Avatar
    Apparently the same product with a different label is sold as a "nail dryer".
    Say what you will, from their ad I learned that while the standard button press turns it on for 45 seconds, a long press turns it on for 60 seconds (time it, this is accurate).
    https://rover.ebay.com/rover/1/711-5...0AAOSwpKRdFHPb
    pizza_pablo likes this.
    08-23-2019 11:55 PM
  1. no software update for s5 active
    By ewikpark in forum Samsung Galaxy S5 Active
    Last Post: 04-04-2018, 12:45 AM
  2. I am unable to use my SD card in Samsung J5
    Last Post: 04-03-2018, 03:42 AM
  3. Replies: 2
    Last Post: 04-02-2018, 02:55 PM
