1. Mwanahabari's Avatar
    Hi. Sorry if it's already been answered elsewhere, but does wireless charging work while a phone is in a case or if it has one of the very thin protective covers on it?
    Cheers.
    04-05-2018 06:45 AM
  2. rjack22's Avatar
    There are some cases whereby wireless charging won't work, but for the most part they do work through the case. It has worked through all the cases that I have had.
    04-05-2018 07:16 AM
  3. anon(8453378)'s Avatar
    I am using the supcase unicorn beetle pro on my s9+ and the wireless charging works flawlessly. On my previous s7, I used a LifeProof case and it also worked well.
    04-05-2018 07:17 AM
  4. chanchan05's Avatar
    Wireless chargers have a range where the induction works. One brand I know of, Tronsmart, lists their chargers as having 0.5cm range, so as long as the distance between charging pad and phone coil is within that, it would work.
    04-05-2018 07:28 AM
  5. Mwanahabari's Avatar
    Thanks all! :-)
    04-05-2018 09:10 AM
  6. bennett22's Avatar
    i have used both an otterbox and the samsung rugged case with 2 different wireless chargers (samsung at home, aftermarket mount in truck) and have not had problems with either, and both chargers were bought when i got my s7
    pizza_pablo likes this.
    04-05-2018 07:22 PM
  1. rooted my s8 and after that while installing s9 custom rom it crashed saying storage corrupted
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-05-2018, 12:56 PM
  2. How do I get my phone contacts back when they vanished after charging?
    Last Post: 04-05-2018, 12:53 PM
  3. Where can I find lock and mask app in my J7 neo
    Last Post: 04-05-2018, 12:51 PM
  4. Samsung J7 keypad has vanished and I cannot unlock my phone.
    Last Post: 04-05-2018, 06:35 AM
  5. Replies: 0
    Last Post: 04-04-2018, 11:25 PM
