1. Mike 9's Avatar
    Anyone having issues connecting to public wifi saying yes connected and then no internet connectivity?
    04-05-2018 09:41 AM
  2. Almeuit's Avatar
    Check and ensure there isn't a page where you need to accept their terms before getting internet.
    04-05-2018 09:58 AM
  3. Mike 9's Avatar
    usually there is but I can't even get to that page. it says connected I go to load google chrome then it says page not found wont even access the page to accept terms
    04-05-2018 12:33 PM
  4. wookiee2cu's Avatar
    Only thing I can think of is maybe the terms & agreements page loaded in another window? By that I mean hit the number of windows icon in the top right and see if one of those previews is the terms & agreement. If not, try clearing your browser cache and history... these are the only suggestions I can think of.
    pizza_pablo likes this.
    04-05-2018 01:59 PM
  5. Pbookuser2's Avatar
    Gosh this question appears in many places, but so far I can't find an answer. I have an Android 6 phone that has this problem, but after trying just about everything, it still wil not connect to PUBLIC wifis. But works fine at home.
    01-11-2020 05:25 PM
  6. B. Diddy's Avatar
    See discussion in your other thread: https://forums.androidcentral.com/an...blic-wifi.html
    01-11-2020 06:34 PM
  1. Samsung Galaxy s9 wifi
    By Mike 9 in forum General Help and How To
    Last Post: 04-05-2018, 02:44 PM
  2. Telephone Calls and Internet BLOCKED by WiFi
    By mc5w in forum General Help and How To
    Last Post: 04-04-2018, 09:34 PM
  3. I have to re-enter my WiFi password everytime I turn my device on
    Last Post: 04-04-2018, 02:00 PM
  4. Can you connect AA to sync3 via wifi?
    Last Post: 04-04-2018, 09:55 AM
  5. Why are some apps not working over wifi but they do over mobile data?
    Last Post: 04-04-2018, 03:35 AM
