1. Nodnerb's Avatar
    Is there not supposed to be a drop down menu with options when you long press on a recent call? Options to block ,call back, text, add to contacts etc. In my recent calls page there is no option to do anything, if I short press on a call it selects it and a "delete" button pops up on the top right. If I long press, the exact same thing happens. I have no options to do anything with my recent call list. Anyone else?
    04-06-2018 10:46 AM
  2. SpookDroid's Avatar
    Nope, not from a long-press. If you tap the number/contact on the list, however, you'll see a menu show up below. There you can Call, Message, Video Call (if enabled), or see Details. From the Details section, you can see more history info and, if not already in your Contacts, get the option to add, update existing, or block the number.
    Long-pressing an item on the Call list will only select it for batch deletion.
    04-06-2018 11:01 AM
  3. Nodnerb's Avatar
    Thanks. It's working now after a reboot. No matter how long or briefly I tapped before it was registering a long press.
    04-06-2018 01:01 PM
  4. SpookDroid's Avatar
    That's odd... was the screen wet by any chance?
    04-06-2018 01:04 PM
  5. Nodnerb's Avatar
    No it wasn't. Just another glitch to add to my list. Hope there's an update soon to fix some of these.
    04-06-2018 02:57 PM
  1. Why can't I find videos I took on my phone?
    By bulllseye in forum Moto Z
    Last Post: 04-11-2018, 04:38 PM
  2. BT headset call quality issues.
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 04-06-2018, 03:19 PM
  3. wickr doesn't accept voice calls?
    Last Post: 04-06-2018, 12:00 PM
  4. Can I change the voicemail notification tone on Samsung S8, Oreo?
    By proudcdnguy in forum Samsung Galaxy S8 & S8+
    Last Post: 04-06-2018, 11:05 AM
  5. change number of favorites shown on phone button long press
    Last Post: 04-06-2018, 09:16 AM
