1. anon(9918034)'s Avatar
    If you enjoyed the piece of mind of Samsung premium care as I did. Which I found to be way better than carrier insurance. Unless you buy the s9 ot s9+ from Samsung you cannot get premium care.
    04-07-2018 09:12 PM
  1. [602] Affiliations is not a member of the user table (602)
    By Android Central Question in forum Android Apps
    Last Post: 10-31-2018, 12:15 PM
  2. Samsung Edge S7 dead screen with blue constant light at the upper left corner
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 04-07-2018, 09:10 PM
  3. Where is the best place to get the least expensive Samsung S7 Verizon carrier
    Last Post: 04-07-2018, 07:50 PM
  4. Samsung Edge S7 dead screen with blue constant light at the upper left corner
    Last Post: 04-07-2018, 06:52 PM
  5. [602] Affiliations is not a member of the user table (602)
    Last Post: 04-07-2018, 06:13 PM
