andrew_ackley
I'm pretty sure I made a mistake in choosing the Pixel 2XL. I'm having terrible noise in my low light pictures. The phone has to be in a warm environment to achieve fast charging. Yes, it's a thing and it still doesn't charge as fast as my S7 under ideal conditions..apparently 65 degrees is too cold for it's sensitive self. NO camera settings Since Verizon has no deals that I can take advantage of right now, I either have to exchange the Pixel and hope that the noise issue was a faulty camera OR return the phone and wait for a new special.
So, I'm gathering some info for the possible S9+ purchase. How does the display compare to the Pixel 2 XL? I'm thinking probably better. Has Samsung's removal of bloatware been enough to make a difference? How's the battery life? The Pixel's is excellent but it's new and it's stock Android. I've seen several camera comparisons. I tend to lean towards the S9+ in most cases but lean to the Pixel's dynamic range and highlights. The Pixel does have voice command camera shutter (I only found it by Googling). You have to say "hey Google, take a picture" and there is a 3 second count down (sigh).
I need to be convinced that it's worth it to return the Pixel 2XL and wait for a sale on the 9+. OTOH, if you don't think it is, convince me to keep the Pixel I've had the Galaxy 4-7. Big fan except for the bloatware. I like the Pro camera mode but if the Pixel doesn't NEED a pro mode, that's cool.
This is soooo confusing! Camera is #1 priority. Google is supposed to take the best pictures while the S9+ has the better/best camera features.
The s9 screen is marginally better. Camerota on my pixel is better imo. Sounds like you just got a buggy unit. Have you tried a factory reset? Also it seems like the biggest android phones are ones restored from a backup. It sounds like 100% of the reason you're thinking of swapping to an s9 could be completely solved by exchanging phones. I'd exchange for another pixel first.
