1. Tammy Grace's Avatar
    I've had my s9 plus for a little over a month now and it's been good but I don't know if I'm being paranoid but over the last few days it has been draining faster than usual. As I said 1% every 5 mins. I never have my brightness over more than half it still lasts me the day but it used to be it would drop 1% every 10 mins or 6%-%10 an hour. I don't put it on charge until prompted. I usually charge it early in the morning as it charges pretty quickly (I don't use fast charge). Sorry for the waffling. I have attached screenshot of battery usage
    Attached Thumbnails Battery draining 1% every 5 mins-screenshot_20180413-200551_settings.jpg
    04-13-2018 05:14 AM
  2. BB_PP's Avatar
    did you transfer data from your old phone ?
    04-13-2018 05:37 AM
  3. bIOforger's Avatar
    Yep Paranoid. Depends on what apps you are using when the screen is on for starters. How the phone is being used / CPU usage etc.
    But your screen on time is excellent, as you have nearly 50% batt left, you're looking at ~ 8-9hrs screen on time! I usually get 5-6hrs total. When the screen is on its gonna drain the battery at the rate you are seeing, there's nothing you can do about that.
    If you are saying its draining at that rate when the screen is off then there's something not quite right, probably an app running in the background.
    Either way to monitor it get a better battery app, so you can see if any apps are keeping the phone awake/using CPU, like GSAM or Better Battery Stats.
    Mine uses <1% per hour when the screen is off. And about the same as you (depending on what app i'm using) when the screen is active.
    Tammy Grace likes this.
    04-13-2018 05:54 AM
  4. Tammy Grace's Avatar
    Thanks
    bIOforger likes this.
    04-13-2018 06:08 AM
  5. Tammy Grace's Avatar
    Yes. An s7 edge
    04-13-2018 06:08 AM
  6. Tammy Grace's Avatar
    I think it maybe uses 1% sometimes 2% when screen isn't on
    04-13-2018 06:16 AM
  7. bIOforger's Avatar
    1% or less is pretty much normal. 2% or more is a bit on the high side, just means an app is running in the background, that could also be for a legitimate reason. Don't worry about it and charge it when you need too.
    04-13-2018 06:25 AM
  8. Tammy Grace's Avatar
    Thank you. Do you think leaving it on the charger when its charged is damaging? I usually take it off charge 10 mins before I need to leave the house.
    04-13-2018 06:34 AM
  9. bIOforger's Avatar
    Np, if you leave it on charge for hours n hours at 100% yes it can be damaging to the battery over time, mind you i do that overnight quite often and never had a problem with the battery in the s9+ or in other phones. Its just more convenient right?
    04-13-2018 06:52 AM
  10. bIOforger's Avatar
    Poor cell reception will also drain the battery more than someone with a strong signal.
    mwake4goten likes this.
    04-13-2018 07:04 AM
  11. rushmore's Avatar
    Yep, more than even a 3D game does.
    04-13-2018 07:16 AM
  12. mwake4goten's Avatar
    You could try the wipe cache in recovery technique, when I get issues like this sometimes doing this will correct excessive battery drain issues.
    Also as a rule whenever I get a new phone I always switch off automatic updates of Google Play store. I then update apps one by one, if I feel I need to (most time not necessary IMHO). This way I can manually update my apps and have more of an idea over which apps are causing draining issues if/when I update them.
    05-14-2018 02:38 PM
  13. karelj's Avatar
    On standby, my battery usually goes from 100% to 96% after 10-11 hours. In use, it loses 1% every 2-3 minutes.
    Not sure if this is normal for a 2 week old Galaxy S9. I figure it's the price to pay for a powerful processor and amazing screen.
    05-15-2018 03:23 PM
  14. Abbers727's Avatar
    I always get paranoid about my battery. Even when it's fine. I have AOD on and I know that's partly why I lose about 1% an hour.
    I JUST downloaded the Gsam app. And it said 83% screen time. :/ I don't know how to lower that. Because I'm sure the AOD might be to blame for screen time being used up so much.
    I even tried downloading Friendly app instead of the Official Facebook app. Because when I look at the info / stats for the Facebook app. It says it uses quite a bit of battery. I also decided to download Messenger Lite.
    05-16-2018 09:17 PM
  15. bIOforger's Avatar
    1% per hour with AOD on is excellent, stop flapping about nothing lol. You can't lower the screentime %, if its on its on, yes AOD counts toward that stat.
    FB/messenger apps have always been batt hogs, a lot better than they used to be in the past mind.
    05-17-2018 03:54 AM
  16. Abbers727's Avatar
    Yeah, I think give or take , it's 1% an hour when I use AOD. Well I set it to turn on at 10am and turn off at 12am. lol.
    05-18-2018 12:21 AM
  1. Why would my battery not start charging
    Last Post: 04-13-2018, 12:04 PM
  2. Notification LED Not Working When On Battery
    By ElAlcahuete in forum Samsung Galaxy S9 & S9+
    Last Post: 04-12-2018, 09:46 PM
  3. Battery Problems after Oreo? Turn off WiFi Calling
    By THEPRFCT10 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-12-2018, 07:49 PM
  4. Re placement battery only charges very slowly with OEM fast charger
    Last Post: 04-12-2018, 06:34 PM
  5. s9 battery case article
    By bennett22 in forum Samsung Galaxy S9 & S9+
    Last Post: 04-12-2018, 06:16 PM
