Very very expensiveI have a Lifeproof Next case on mine and I like it, seems very protective but doesn't cover the glass. It does have a lip that is higher than the screen if I place it face down. Not a cheap case though at $79.
This one?try spigen tough armor or spigen neo hybrid. the tough armor feels a bit stronger and the neo hybrid looks better
It's very cheap, I buy it thanks so with this cover I can put the phone face down without any problem to the screen?
Well is it obvious. I don't put the phone on a rockif the surface is fairly flat like glass, wood, plastic then yes. but if it is like stone pebbles then probably not
