04-14-2018 11:15 AM
27 12
tools
  1. Ryza321's Avatar
    Hi guys, I put it face up as I feel there is less chance to scratch the screen. But, I want to start to keep it face down sometimes in order to turn off aod when I need but I don't want to risk to scratch the phone. What do you think? This is my cover and I don't use any screen protector
    04-13-2018 03:26 PM
  2. makaroni's Avatar
    I don't think the AOD shuts off even with the phone face down on the S9 so it won't matter. Just get a case with a border high enough to prevent the screen from touching a surface if you put the phone face down. The case you have doesn't look that thick. As long as you're not rubbing it on the surface you should be good.
    04-13-2018 03:33 PM
  3. lindajm22's Avatar
    AOD does shut off with the S9+ when placed face down. Comes bank on immediately when picked up. You can set a time for the AOD to be off so if you don't want it on, say, at night, you can set on and off times.
    04-13-2018 04:16 PM
  4. Ryza321's Avatar
    Yes, I knot that I can set a time, but during the day I just want to be able to shut it off whenever I want simply putting the phone face down, but as I said I don't want to risk to scratch the screen
    04-13-2018 05:02 PM
  5. lucianus_luciferus's Avatar
    you need a case with bigger top and bottom lips
    that way when you put the phone face down the screen will not touch the table
    04-13-2018 05:50 PM
  6. rimz808's Avatar
    Is that a default setting, AOD shuts off when the S9+ is faced down?
    04-13-2018 06:22 PM
  7. lindajm22's Avatar
    I'm really not sure. I just looked at the AOD settings and it's not in there and I'm not sure now if it was a setting somewhere else or if it just always works like that. I know my screen with AOD on will go black placed face down. I'll try to find a setting.
    04-13-2018 07:26 PM
  8. chazglenn3's Avatar
    It's a feature to prevent unnecessary battery drain while the phone is in a pocket, purse or face down on table. There is no setting to turn it on or off.
    04-13-2018 07:29 PM
  9. lindajm22's Avatar
    I would not put it face down unless the lip of the case comes up over the top of the screen, above the curve. Yours doesn't appear to be high enough.
    04-13-2018 07:35 PM
  10. lindajm22's Avatar
    Thanks! Glad I didn't spend too much time looking for that.
    04-13-2018 07:38 PM
  11. JW_SC's Avatar
    Not a shill by any means; but the front is made of Corning® Gorilla® Glass 5; you're fine.
    It's probably the strongest part of the phone. Face down, you're good.
    Now, my Oakley's with iridium coating.... I'm not sure they've ever been even CLOSE to touching a hard surface.
    04-13-2018 11:38 PM
  12. Ryza321's Avatar
    And what cover do you suggest to buy?
    Not a shill by any means; but the front is made of Corning Gorilla Glass 5; you're fine.
    This is what I thought, but apparently it seems that without a cover, the screen can get scratched if the phone is face down. I don't get it
    04-14-2018 01:28 AM
  13. chanchan05's Avatar
    And what cover do you suggest to buy? This is what I thought, but apparently it seems that without a cover, the screen can get scratched if the phone is face down. I don't get it
    Get one of those armor cases. You can watch Flossy's case reviews. If he says the case is slamboy approved, that means the screen is raised far enough from the table.
    It's gonna get scratched because there are a lot of things in this world that's harder than glass. A single speck of sand getting under your screen and then you pull it off and it slides a little, then boom you got a scratch. I never had a scratch before my S7 Edge and never used a protector, but I always had armor cases. I decided to go for a similar case to yours on the S7 and continued to put it face down. Next thing I knoe there a pretty deep scar that came out of nowhere.
    04-14-2018 02:24 AM
  14. BerryBubbles's Avatar
    Get one of those armor cases. You can watch Flossy's case reviews. If he says the case is slamboy approved, that means the screen is raised far enough from the table. (Snip)
    I enjoy Flossy's reviews. When he says it's slamboy approved & hits the table the with the phone face down, the whole table shakes. He's pretty convincing!
    chanchan05 likes this.
    04-14-2018 04:18 AM
  15. Ryza321's Avatar
    Can you suggest a specific cheap cover which is slamboy approved and that I can buy on Amazon? I'm not English so I have a little bit of difficulty to watch those reviews
    04-14-2018 04:25 AM
  16. chanchan05's Avatar
    Cheap is relative though. I suggest looking at cases made by UAG. Some Spigen cases you can look at is the tough armor and the slim armor.
    04-14-2018 04:44 AM
  17. Ryza321's Avatar
    I prefer the spigen since I know them. What model do you suggest? I looked on Amazon, but I don't understand if the cover is "slamboy approved" or not. They seems all similar to me
    04-14-2018 04:49 AM
  18. chanchan05's Avatar
    Look for the tough armor. Check the link. There's a version for both S9 and S9+
    https://www.spigen.com/collections/g...t=570764722177
    04-14-2018 04:52 AM
  19. Ryza321's Avatar
    Thanks!
    04-14-2018 05:03 AM
  20. lindajm22's Avatar
    I have a Lifeproof Next case on mine and I like it, seems very protective but doesn't cover the glass. It does have a lip that is higher than the screen if I place it face down. Not a cheap case though at $79.
    04-14-2018 07:02 AM
  21. Ryza321's Avatar
    Very very expensive
    04-14-2018 07:08 AM
  22. lucianus_luciferus's Avatar
    try spigen tough armor or spigen neo hybrid. the tough armor feels a bit stronger and the neo hybrid looks better
    04-14-2018 07:19 AM
  23. Ryza321's Avatar
    This one?
    04-14-2018 07:43 AM
  24. lucianus_luciferus's Avatar
    04-14-2018 07:53 AM
  25. Ryza321's Avatar
    yep
    It's very cheap, I buy it thanks so with this cover I can put the phone face down without any problem to the screen?
    04-14-2018 08:54 AM
27 12
  1. Looking to buy a smart phone with decent specs for my 12 year old son? TIA.
    By Rubberman365 in forum General Help and How To
    Last Post: 04-23-2018, 01:02 PM
  2. Why my phone wont update or download from Google play?
    Last Post: 04-13-2018, 04:56 PM
  3. why is my dead trigger 2 game always crashing plainly after the tutorial?
    Last Post: 04-13-2018, 03:24 PM
  4. Samsung Galaxy Grand Prime smart phone
    Last Post: 04-13-2018, 01:21 PM
