Originally Posted by
Rukbat And since a Qi coil is about 2" in diameter, that's a serious hole. I'd rather have a solid metal back.
I hear you, and wish it was possible. I'd rather have an S5 type back I can take off, a user swappable battery and a firm SD card holder and sim, not this 'I hope I don't break it' slide out tray.
I added qi charging to the old S5 (yes, the part fit just fine inside), and it worked fine.
These glass backs, and I know I've said it before, is just so they can sell and fix more phones.
Patiently waiting for the 10. If they use the coming new plastic on the front, they better not make the back glass.
