Cleaning and sanitizing your S9
Re: Cleaning and sanitizing you S9
Just a decent microfibre cloth to polish up the glass.
I use eyeglass cleaner and the cloth I use to wipe my glasses
Ultraviolet method here to sanitize. I wipe the screen with a lens cloth to remove fingerprints.
Android Central posted a really good article about cleaning your phone a few weeks ago! Amazon sells some good cleaning kits as well!
Damp Microfiber cloth does the trick.
Using an alcohol wipe for your screen once to put a screen protector on is fine. To use it often to clean your screen is bad news for the long term of your screens oleophobic coating.
ya, plus overkill :)
Just a soft cloth, damp if necessary. Occasionally use a couple shots from a can of compressed air to clean out the speaker grills--short, sweeping bursts about 6" away from the phone to avoid damaging the speakers.
I use Zeiss Lens cleaner spray/wipes to clean and disinfect my phone. It contains 70% alcohol so I use their non alcohol version if just wiping down my phone for smudges/fingerprints or just hit it with a micro-fiber cloth.
Zeiss works well for me and isn't expensive. You can get a lens cleaning package for around 5$ that has the spray, wipes and micro fiber cloths. Its lint and ammonia-free and the wipes are non-abrasive, anti-static, micro-fine tissue.
So, you clean your phone? How do you get a phone dirty in the first place?
Yes, I definitely clean my phone. They get dirty quite easily and microorganisms like bacteria can be on it since we are touching them all day everyday.
I want to keep my phone clean, functional and looking good for as long as possible - especially for what I'm paying for it.
I rinse my phone under a running (low-pressure) tap, wipe it (except the lenses) with a paper towel & then wipe the lenses with a lens cloth.
To me, anything else is overkill.
Iknownothin
