    I liked being able to change those on my Samsung in previous years.
    04-17-2018 03:14 PM
  2. SDTRMG's Avatar
    you can change the background, you just pick a option and in the dots menu the option should be there.
    04-17-2018 03:50 PM
  3. r511's Avatar
    You mean the wallpaper?
    04-17-2018 07:50 PM
  4. ScottsoNJ's Avatar
    You have to change the theme to change the background
    04-17-2018 10:21 PM
  5. bIOforger's Avatar
    No you don't, just go into Samsung themes, Wallpaper n click on View all at the top, then you can pick your own from gallery or one of the stock wallpapers.
    04-18-2018 07:43 AM
  6. wookiee2cu's Avatar
    I wonder if the OP is talking about the background in the stock messaging app. If that is the case then I don't think anyone would be in the know if Samsung is planning an update for that or not. I've read that there are 3rd party messaging apps that will let you customize the background though.
    04-18-2018 02:53 PM
  1. S8 Talk to text stops working after update.
    By mfarre03 in forum Samsung Galaxy S8 & S8+
    Last Post: 04-27-2018, 06:25 AM
  2. Best Buy Verizon S9+ $462 with dpp and bill credits
    By dpham00 in forum Samsung Galaxy S9 & S9+
    Last Post: 04-22-2018, 01:08 PM
  3. How do i update my prl on my phone
    Last Post: 04-17-2018, 06:55 PM
  4. Why are my emails going direct to Spambox
    Last Post: 04-17-2018, 06:54 PM
  5. Replies: 1
    Last Post: 04-17-2018, 03:23 PM
