Save big + get 3 months free! Sign up for ExpressVPN today
  1. Toheedbutt1234's Avatar
    So I bought s9plus 4 days ago and was really worried because of the battery life I was getting. 8 hours and my device would just die. But after first 2 cycles it started to show it's power! Now I am on my 4th cycle and getting 24h up time with 7-8 hours screen on time with radio and wifi on all the time(24hours) . I am really really happy with this device. I love it!
    Btw I am using exynos version !
    04-19-2018 08:55 AM
  2. bIOforger's Avatar
    See told you enjoy.
    Toheedbutt1234 likes this.
    04-19-2018 10:31 AM
  3. jeetu4444's Avatar
    same here....using exynos version 128gb variant Indian version....getting excellent battery life....even with lot of smart view feature....basically screen mirroring
    Get any around 1.5 days to 2 days depending on my use
    04-19-2018 11:03 AM
  4. rimz808's Avatar
    lucky. had mine for about a month now. battery did improve, but on average only getting about 3.5 SOT. it lasts thru the day so I'm ok with that. but oh to see it last long like others.. I'll still keep dreaming.
    04-19-2018 11:42 AM
  5. strikeIII's Avatar
    This is always a subjective topic. It will always depend on individual usage. I will never get great battery life with any device because of the way I use it. I've come to terms with that long ago and have just worked around it.
    04-19-2018 02:58 PM
  6. scottbeamer's Avatar
    THIS.
    I've never gotten as much as a half day charge on a smartphone. I'm a very heavy user, with lots of apps running in the background (e. g. numerous news organizations).
    With that said, my S9+ has the best battery life of any smartphone that I've owned.
    strikeIII likes this.
    04-19-2018 03:23 PM
  7. Toheedbutt1234's Avatar
    3rd cycle completed
    Attached Thumbnails s9plus battery after 4 days!-screenshot_20180420-091153_gsam-battery-monitor.jpg
    04-19-2018 11:18 PM
  8. exile0229's Avatar
    My numbers, while idle, are almost as good. Had to set my alarm and realized that I hadn't charged my S9+ (Snapdragon). Here are the battery numbers: at 44 hours on battery, I still had 13% and 4 hours remaining. Backstory, I was down for a few days with a tremendous allergy/cold issue and was unable to clearly see my phone so little use. I'm able to get 24 hours of moderate use. Coming from the S7 Active with 4000mA battery, I'm impressed.
    Attached Thumbnails s9plus battery after 4 days!-screenshot_20180422-044646_settings.jpg   s9plus battery after 4 days!-screenshot_20180422-044814_settings.jpg   s9plus battery after 4 days!-screenshot_20180422-044802_device-maintenance.jpg
    bIOforger likes this.
    04-23-2018 04:10 PM
  9. bIOforger's Avatar
    What theme are you using there? i like the burgundy overlay colour.
    04-23-2018 05:32 PM
  10. ssj100's Avatar
    Not many posts regarding battery life on this phone? Lots of misleading information out there, but I'm quite impressed with real-world battery life so far. I'm usually quite a light user. Some specs and information to put things in context:
    -Exynos version, WQHD+ resolution. Not rooted, but I did factory reset before using the phone
    -Auto-brightness enabled
    -AOD enabled the entire time
    -Several apps that I don't use are uninstalled or disabled (eg. Chrome/YouTube are disabled as I use Samsung's built in browser instead for most internet-related activities)
    -Most auto-syncing and auto-updating processes are disabled (I don't do this to save battery life - it's just that I like to be in control with most things on my phone (and laptop/PC too for that matter)
    -Several hours of movie watching in the dark (probably why the SOT is so high)
    -Nearly 3 hours of GPS (High accuracy) with mobile data enabled (mostly 4G and 3G)
    -A few hours of bluetooth connectivity to either car or external speaker device
    -Other miscellaneous activities like short spurts of web browsing, listening to music directly from the phone, several text messages and short phone calls etc.
    -Phone drained until it shut down as you can see in the screenshot - it's connected to a charger with fast charging disabled.
    04-28-2018 09:29 PM
  11. nuraidairawan's Avatar
    its same like my own samsung galaxy s9 here ...should i bring to service samsung?
    04-28-2018 11:10 PM
  1. Battery is horrible today
    By Tcbemis in forum Samsung Galaxy S8 & S8+
    Last Post: 04-19-2018, 07:41 PM
  2. My Droid Maxx battery dies extremely fast
    Last Post: 04-19-2018, 01:50 PM
  3. alarm clock issue after Android update to 8.1 on Pixel XL phone
    Last Post: 04-19-2018, 10:24 AM
  4. Note 8 - after taking phone off silence all notifications sounds play at once
    Last Post: 04-19-2018, 08:11 AM
  5. Media volume pump up automatically after phone call ends
    Last Post: 04-19-2018, 07:50 AM
