07-16-2018 08:54 AM
33 12
tools
  1. jhimmel's Avatar
    Well, if the leak is true, the Note 9 HAS A FLAT SCREEN!! If this leak is true then indeed you NEED to wait for the Note 9. Flat, large screen with the Spen is amazing. This will blue the s9 plus away. Shouldn't even be a contender.
    https://www.forbes.com/sites/gordonk.../#60483a7d1440
    Where are you getting your rumor of a flat screen Note 9? You keep pointing to an article about the upgraded Asian market S9.
    04-24-2018 08:58 PM
  2. scottbeamer's Avatar
    I never used the S-Pen on my Note.
    04-24-2018 11:59 PM
  3. tadpoles's Avatar
    Right, but that article is a month old and says nothing about a flat screen.
    The concept render showed it but that's all it is, a concept render.
    04-25-2018 01:41 AM
  4. David Martrano's Avatar
    I use the s8+ as my daily. It's been a great performer. I skipped the s9+, minimal upgrade. But the note9 definitely holds my interest. The stereo speakers are very welcomed & if it has the proposed larger battery I'm all in. I will pre-order for the first time, and never owned a note before. I really enjoy all the premium features Samsung has to offer!
    04-25-2018 09:46 AM
  5. Jaycemiskel's Avatar
    Looks curved to me. I'm sure if it was flat they would have made a big deal about it. There's absolutely no credible information pointing to a flat Note 9. It's just wishful thinking and mistaking that article about the upgraded S9 for the Note 9.
    jhimmel likes this.
    04-25-2018 11:10 PM
  6. Chesarato1's Avatar
    If you want a note (totally different from the S line - go to the store and play with a Note 8 to see if you fall in love with the things you can do with the S-Pen, or if you think it will grow old without ever being used), I'd wait until at least a month after the Note 9 is released. Samsung has been known to release some dogs, and never really get them working. (And even though they offered replacement models after the Note 7 fun, many people were still dissatisfied. An S7?That's not a Note anything.) I did the same thing for the S8 - and ended up, after years of Samsungs, with a Pixel 2.
    05-13-2018 02:48 PM
  7. jabtano's Avatar
    My take is this. IF YOUR ON T-Mo It will be black or gray as they don't do colors. I like my note8 but it tends to lag, or doesn't react when I press the screen. Im going to wait until after the fall I want to see everything before I out down another grand, for a phone that will be obsolete in 4months.
    07-11-2018 07:59 PM
  8. Hermes Hidayat's Avatar
    I just switched from my 64GB Note 8 to 255GB S9P... I would wait for S10...
    Alan Sims likes this.
    07-16-2018 08:54 AM
33 12
  1. Replies: 6
    Last Post: 04-23-2018, 04:51 AM
  2. I can't get to set up ringtones on galaxy s5
    Last Post: 04-22-2018, 04:56 PM
  3. Verizon S7 blocking 4G when wireless tries to connect.
    Last Post: 04-22-2018, 02:11 PM
  4. Replies: 1
    Last Post: 04-22-2018, 01:59 PM
  5. Replies: 0
    Last Post: 04-22-2018, 10:20 AM
