1. lindajm22's Avatar
    The contacts that I set in my People Edge keep randomly disappearing. Has anyone else used the People Edge and seen this?
    04-27-2018 08:18 PM
  2. martyn30162's Avatar
    happened a couple of times since I got the phone . When cleaning memory it's wiping the edge panel
    lindajm22 likes this.
    04-29-2018 12:01 PM
  3. monicakm's Avatar
    I've GOT to start remembering to use that! But no, the few (five) contacts I have in the People Edge haven't disappeared.
    04-29-2018 05:27 PM
  4. lindajm22's Avatar
    I ended up removing it and I just added it back to try it again and noticed you now have 10 spots where it used to be only 5 so it must have been updated. I'll give it another try. It's just so weird, I'll go to use it and one or two will be missing. All the time.
    04-29-2018 06:18 PM
  5. lindajm22's Avatar
    And overnight 4 of my 7 contacts disappeared again.
    04-30-2018 05:37 AM
  6. alt075's Avatar
    My edge panels I cant even open and it is turned on.
    04-30-2018 05:50 PM
  1. Minor problem regarding the samsung music player
    By DomKennedi71 in forum Samsung Galaxy S9 & S9+
    Last Post: 05-02-2018, 05:27 AM
  2. Couldn't Update-Installation Problem message
    By technutcounselor in forum Essential Phone
    Last Post: 04-29-2018, 06:50 PM
  3. S6 Edge Plus in 2018
    By Paul Guest1 in forum Samsung Galaxy S6 edge+
    Last Post: 04-27-2018, 07:59 PM
  4. Minor problem regarding the samsung music player
    By DomKennedi71 in forum Ask a Question
    Last Post: 04-27-2018, 04:51 PM
  5. There s a purple spot in the edge of my phone screen
    Last Post: 04-27-2018, 08:55 AM
