    When I use voice for texting it's not writing it out as a text
    04-30-2018 03:42 PM
  2. Itsa_Me_Mario's Avatar
    Which app and keyboard are you using? Is it sending a voice file instead of transcribing it?
    04-30-2018 05:07 PM
  3. alt075's Avatar
    I just talked to a technician from tmobile whom I go thru for a different issue. He mentioned text to speech for s9 not working. I was unaware. Mine is not working also. I think he said Samsung is aware of this issue. My edge panels are not working as well. But that is the first he has heard of my issue. So doing a factory reset to see if that fixes my issue I'm having. Since I saw this I thought I'd share that info with you.
    Itsa_Me_Mario likes this.
    04-30-2018 06:45 PM
  1. Samsung earbud controls not working
    By Kodietoad in forum Samsung Galaxy S8 & S8+
    Last Post: 10-05-2018, 12:06 PM
  2. I have no Bixby Voice on my S8+
    By Osprinow in forum Samsung Galaxy S8 & S8+
    Last Post: 05-01-2018, 12:43 PM
  3. Snapchat can't connect to server error
    By Lauraeno in forum Ask a Question
    Last Post: 04-30-2018, 06:14 PM
