Hey Android Central Community!!
I just got my S9+ and couldn't be happier!!! Just left the s8 and decided it was time for a bigger phone.
I don't use my phone for a whole hell of a lot but when I use it, I like it to work the way past ones have. I've come to a problem now. Google play music - galaxy s9+ - streaming to car audio..
Let me be a little more clear....with the s8 I used to have problems with the equalizer dampening the sound when streamed into the truck. I listen to everything: rock, classic rock, hip hop, electronic, trance etc. I noticed with the s8 if I got a text message or any type of notification, it would sometimes dull the sound and not bring it back up to level. I would have to turn the truck off and the Bluetooth of my phone and reconnect the connection. I found if I turned the equalizer off through app selections, I could avoid this said problem.
With the S9+ I IMMEDIATELY noticed a change in quality. It sounds, clearer, I could say. But the guitar riffs don't seem to have the effect they did. Listening to electronic or hip hop there is no bass with the volume at 12. I have to turn the volume to 19 in my truck. (2018 f150 with Sony speakers) with the s8, at 12, the mirror would shake.
I have been through every option in the S9+ equalizer and have tried to adjust every option to get the original sound back, but I can not get it. Can anyone suggest an app to buy or download for free that I can adjust better...? I'm lost. I just want my old sound back!!!
