1. Steve Waring's Avatar
    I have a new S9+. Sidesync does not work on S9, it has been replaced by Samsung Flow. But on the PC Samsung Flow requires Windows 10 and I have Windows 7 (which I much prefer).
    Are there any decent third party apps that do the same? Besides the screen sharing, in order of preference, other features of sidesync I use are:
    Shared copy/paste buffer.
    Open phone browser page in PC browser.
    Notification's on PC also in separate window.
    Drag and drop file sharing.
    05-17-2018 06:50 AM
  2. illdini's Avatar
    Sidesync still works, I have it on my S9+. Download it from the Play Store. I think it's wifi only tho (no Bluetooth or USB - I'll check today if I get a chance).
    05-17-2018 09:50 AM
  3. strikeIII's Avatar
    Well from a security perspective you might as well jump to Windows 10 as Windows 7 is no longer supported for non-enterprise OS.
    EDIT: Correction, I guess Microsoft will continue to release security patches until 2020 so I guess you're still safe. Carry on.
    05-17-2018 11:03 AM
  4. Steve Waring's Avatar
    No, it does not show up on the Playstore for Oreo. You must have downloaded it, before it was pulled for Oreo onwards. If yours is still working, don't uninstall it, because you won't be able to get it back.
    05-18-2018 02:58 PM
  5. L0n3N1nja's Avatar
    https://play.google.com/store/apps/d...oid.sidesync30
    Perhaps a direct link to it on the play store will allow you to install it.
    05-18-2018 03:05 PM
  6. r511's Avatar
    Not available for me.
    05-18-2018 08:30 PM
  1. Gif Bar has no search bar to look for gifs, how do I get it to appear?
    Last Post: 08-31-2018, 12:20 PM
  2. Moved to Verizon from T-Mobile
    By amyf27 in forum General Carrier Discussion
    Last Post: 05-28-2018, 01:04 AM
  3. Browse phone storage when mounted to PC.
    By kolack in forum General Help and How To
    Last Post: 05-17-2018, 12:19 PM
  4. My phone can't sign in to Hangout
    Last Post: 05-17-2018, 09:00 AM
  5. How do I reset an bypass a goggle account on a Samsung galaxy phone
    Last Post: 05-17-2018, 05:28 AM
