1. Ryza321's Avatar
    Is there a way to turn up the notifications or ringtone volume with multimedia buttons? Right now, if I press volume up or down, I can change only the multimedia volume
    Ceanadach likes this.
    05-19-2018 08:42 AM
  2. Golfdriver97's Avatar
    There should be a drop down arrow when the volumes come up. You can click that and get more volume options.
    Laura Knotek likes this.
    05-19-2018 10:38 AM
  3. amyf27's Avatar
    Ryza321 likes this.
    05-19-2018 01:41 PM
  4. lucianus_luciferus's Avatar
    Press volume up or down then tap on the drop down arrow on the top right corner then disable using volume keys for media
    https://image.ibb.co/jksc6T/20180519_201830.jpg
    05-19-2018 03:22 PM
  5. pbksoft's Avatar
    Individual apps can select volume of which sound stream is controlled by multimedia buttons. Usually music players tell the system that the media stream is the one, so as long as you have these apps open in the foreground, it works as you described. But if you close these apps and switch to some others that do not play anything, probably you will control ringer and notofocations volume by multimedia buttons.
    05-20-2018 12:25 PM
  6. Ryza321's Avatar
    No, if I don't use any multimedia apps, I always get the media slider when I press the volume's buttons. A nnyway I solved the problem with the previous users suggestion, so thanks a lot guys!
    05-27-2018 02:27 AM
  1. Replies: 1
    Last Post: 05-19-2018, 08:04 AM
  2. Replies: 1
    Last Post: 05-19-2018, 08:03 AM
  3. Replies: 1
    Last Post: 05-19-2018, 08:02 AM
  4. Recommend Some phone with 8.0 version.
    By mali01 in forum Android 8.0 Oreo
    Last Post: 05-19-2018, 03:15 AM
  5. Free APP- Surah Yasin Mp3 With Multiple Languages
    By mali01 in forum Android Apps
    Last Post: 05-19-2018, 02:41 AM
