1. scottbeamer's Avatar
    See the screenshot.
    tadpoles likes this.
    05-28-2018 07:17 PM
  2. chanchan05's Avatar
    I think that means the AOD is animated
    scottbeamer likes this.
    05-28-2018 07:19 PM
  3. scottbeamer's Avatar
    Thanks.
    That reminds me, do you have to manually change the AOD, if it's part of a Samsung theme that you've applied? Mine never changes.
    05-28-2018 07:27 PM
  4. tadpoles's Avatar
    Thanks for pointing me to that theme.
    05-28-2018 09:32 PM
  5. chanchan05's Avatar
    Thanks.
    I don't think so. Last time I tried one out with animation was on S7 Nougat. The AOD automatically changed.
    05-28-2018 09:50 PM
  6. scottbeamer's Avatar
    I would think it should automatically apply with the theme, but it's not happening.
    05-28-2018 10:04 PM
  1. Replies: 1
    Last Post: 05-28-2018, 07:34 PM
  2. How can I change conversation theme on LG Aristo 2
    Last Post: 05-28-2018, 06:58 PM
  3. Android auto works well for a while then stops working in my Holden Captiva
    Last Post: 05-28-2018, 06:44 PM
  4. How do i delete all pic.i sent in text messaging with a contact
    Last Post: 05-28-2018, 06:27 PM
  5. Doe cycling through RGB reudce burn in?
    Last Post: 05-28-2018, 06:24 PM
