    I bought my S9 plus three months back. Today, i had to take the sim/memory card slot out to put a new micro sd memory card. I started hearing rattling sound right after it. Everything is working. Google tells me its OIS but its annoying. Should i keep the phone or have it exchanged?
    05-30-2018 06:06 PM
  2. jeetu4444's Avatar
    Yes has to be the ois or sim or sd card are losse...check the tray
    Morty2264 likes this.
    05-31-2018 05:55 AM
  3. anony_mouse's Avatar
    This can happen if you shake the phone too much. Something comes loose inside and you hear it rattle.
    05-31-2018 09:40 AM
  4. Fred98TJ's Avatar
    Don’t shake it. Simple. :-p
    05-31-2018 09:48 PM
  5. Fred98TJ's Avatar
    Why are you shaking it anyway.
    05-31-2018 09:48 PM
  6. Garz's Avatar
    Likely the camera
    05-31-2018 10:48 PM
  1. Why can't any SMS backup app see my whole conversations?
    By AndroidVageta in forum General Help and How To
    Last Post: 05-31-2018, 08:39 PM
  2. Error occur while creating a folder in audio manager.. can someone help me?
    Last Post: 05-31-2018, 06:59 PM
  3. my weather widget is showing two different times
    Last Post: 05-31-2018, 06:56 PM
  4. Why is there pop ups on my phone ?
    Last Post: 05-30-2018, 05:56 PM
  5. Is a VPN required in rented house
    By Bobby500 in forum Android Apps
    Last Post: 05-30-2018, 04:21 PM
