1. justplainlucas's Avatar
    Ok, so I just got my new S9+ and came across two things I can't figure out.
    One: When viewing text messages, long texts are cut off with a "view all" option to view the entire message. Is there a way to change that so it displays entire messages by default?
    Two: Is there a way to add a Weather FaceWidget to the Always-On display?
    Thanks in advance!
    06-01-2018 11:36 PM
  2. stmax's Avatar
    Thanks in advance!
    Hi yup... that's how the messaging app works now. I have gotten used to it now and actually like the full view after the tap for long messages.
    Re weather... I dont use AOD because I rely on my Gear S3 for persistent information. (Another reason I use stock messages and email as well).
    But I heard some people have used weather apps with a notification icon to shownthatnon AOD.
    06-02-2018 01:02 AM
  3. ABOSWORTH007's Avatar
    The way they condense the message and make you click to see the full message is just obnoxious. I don't know why anyone would want that "feature." They should make a way to disable it but they don't. The only way to avoid this is to get a 3rd party messaging app.
    06-02-2018 06:57 AM
  1. What's the meaning of a man in a circle on the s9 galaxy
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 06-13-2018, 06:20 PM
  2. How to delete printer error On oppof1s
    Last Post: 06-03-2018, 11:52 PM
  3. HTC U12+ question
    By PachecoCorporationCeo in forum HTC U12+
    Last Post: 06-03-2018, 02:28 AM
  4. So I have a 7edge and my app for my camera stopped working. What do I do
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 06-02-2018, 06:07 AM
