1. scottbeamer's Avatar
    Is this normal behavior?
    06-07-2018 08:37 AM
  2. SpookDroid's Avatar
    Does it happen with any theme or a specific one? It's definitely not normal, but if it's a specific theme, it might not be fully compatible with the S9. Also, make sure you don't have any UI-altering apps on top of themes that might conflict with things.
    06-07-2018 12:29 PM
  3. scottbeamer's Avatar
    It happens with almost every theme.
    Would Nova Launcher be a "UI altering app"?
    06-07-2018 02:22 PM
  4. SpookDroid's Avatar
    No, Nova shouldn't interfere with the UI, only maybe icon sets and wallpapers. Try clearing Theme's cache and see if that helps. I haven't seen any reboots on mine with the themes I've tried.
    06-07-2018 04:41 PM
  5. scottbeamer's Avatar
    The Samsung theme or the Nova theme (icon pack)?
    The reboot happens only once (after the Samsung theme is first installed).
    06-07-2018 05:30 PM
  6. tube517's Avatar
    So, it has only rebooted once after the Samsung theme was applied and that's it?
    Actually, a reboot by the user, (not a random reboot )is good after a theme is applied. BUT, it's not normal for the phone to reboot. Is this a theme from the Samsung store?
    I would uninstall Nova if you no longer use it. You can always backup any current desktops on Nova and uninstall and reinstall later if you want to use it again.
    06-07-2018 05:50 PM
  7. scottbeamer's Avatar
    Yes, as I said before, it reboots after applying a Samsung theme (aren't all Samsung Themes from the Samsung Theme store?).
    As for Nova, I never said that I no longer use it.
    I use it all the time.
    Samsung theme for the Quick Settings menu, settings app, and all Samsung apps.
    Nova theme for icons and wallpaper.
    They shouldn't interfere with one another.
    06-07-2018 06:39 PM
  8. SpookDroid's Avatar
    I agree, they shouldn't interfere so something is wrong with your theme engine. To check if it is Nova, for some reason, try switching to the stock launcher and applying a theme you know reboots the phone.
    lucianus_luciferus likes this.
    06-08-2018 12:48 AM
  9. LCW's Avatar
    I'm running the "High Contrast Theme: Sky Black" and it is awesome! No issues at all.
    06-12-2018 08:36 PM
  10. scottbeamer's Avatar
    Thanks for the suggestion.
    I tried that. It still reboots.
    06-13-2018 06:25 PM
  1. My Android Receives Ad Sms Even Though I Don't Have A Sim
    Last Post: 06-07-2018, 10:19 AM
  2. Can't get my Nexus 5X to sync with my Google Calendar
    Last Post: 06-07-2018, 10:17 AM
  3. how do i reset the touch sensor on my zte sonata 3
    Last Post: 06-07-2018, 10:13 AM
  4. Why is my phone switching off by itself
    Last Post: 06-07-2018, 08:27 AM
  5. Replies: 0
    Last Post: 06-07-2018, 08:07 AM
