08-24-2018 10:26 PM
29 12
tools
  1. Joshua Luther2's Avatar
    I am so annoyed every time I want to turn the volume up on my S9 I get the pop up warning about th volume. Does anyone know of a way to disable this pop up. So many times I want to turn up the volume while the phone is in my pocket and can't until I dismiss the pop up.
    Denisew 1972 and kct1975 like this.
    06-12-2018 07:52 AM
  2. SDTRMG's Avatar
    I haven't found a way either, I agree it can be quite annoying, samsung needs to put a "Dont Show Again" option
    kct1975 likes this.
    06-12-2018 08:29 AM
  3. andrew_ackley's Avatar
    This has been a issue with every samsung phone that I can remember. I want to say if you're using a bluetooth headset it can remember your choice/volume but I'm not 100%
    06-12-2018 10:10 AM
  4. Mooncatt's Avatar
    It's not just a Samsung thing, but rather Android itself. All phones have this now. I haven't found a way to completely stop it, but I have had mixed success with this app. I still got the nag message, just not as often as I did without the app.
    https://play.google.com/store/apps/d...d.hearingsaver
    06-12-2018 10:19 AM
  5. bbgpsuser's Avatar
    This was forced onto mobile phone manufacturers back in 2013 by the European standards board.
    Here is one article on how to use Tasker to disable it. https://www.xda-developers.com/how-t...-without-root/
    waqqas31 likes this.
    06-12-2018 10:56 AM
  6. Joshua Luther2's Avatar
    I downloaded Hearing Saver. So far it's working well.
    06-12-2018 05:46 PM
  7. stmax's Avatar
    I was tired of this and it is actually counter productive to what they are trying to accomplish. They are trying to cover their butt for liability to hearing loss but they will cause an accident because I have to fiddle when launching music in my car.
    I used to use tasker but I don't have it on my phone anymore. So I created a bixby quick command called "Play Bluetooth Audio." This cranks my volume and opens music with one command.
    kct1975 likes this.
    06-12-2018 08:08 PM
  8. B0WIE's Avatar
    They don't though... My last 3 HTCs didn't have it and my G7 doesn't. I only know about it because my wife's last phone had it.
    The nonsense bit of it is that if you use high-impedance headphones like I do, full-volume might not be loud at all, but you still have to endure the annoying warning.
    06-13-2018 09:25 AM
  9. Mooncatt's Avatar
    My HTC M8, LG G4, and LG V20 have all had this message pop up, and it's been asked about here for other phones as well. I guess it's possible that some variants of phones may not have it, but my point that this is not just a Samsung issue still stands.
    06-13-2018 12:14 PM
  10. Johnly's Avatar
    It annoys me as well, but honestly it is one gesture for my entire music session. I know, medical advances in hearing aids and implants almost make it okay to pound ones own labyrinth mounted ossicles into haptic euphoria
    06-13-2018 03:13 PM
  11. Morty2264's Avatar
    I had this issue on my Honor 8; but I seem to remember disabling the notification - perhaps because it was an EMUI OS. Haven't attempted a solution with my Pixel 2 yet. Thank you for the app recommendation!
    06-13-2018 11:00 PM
  12. scottbeamer's Avatar
    Every smartphone I've ever owned has had it.
    LG V20.
    Samsung Galaxy S, S2, S3, S5, Note 4, and S9+.
    06-13-2018 11:59 PM
  13. Luke pruitt's Avatar
    Check out an app called SamTweak. One of its tweaks is to disable max volume warning.
    https://play.google.com/store/apps/d...nteks.samtweak
    06-14-2018 11:23 AM
  14. joemontana57's Avatar
    Thank you for mentioning Sam tweak. I installed it, hoping it will work!
    06-15-2018 12:48 AM
  15. r511's Avatar
    Sam Tweak solves this annoying problem for sure.
    06-15-2018 01:18 AM
  16. scottbeamer's Avatar
    Sam tweak looks pretty complicated.
    06-15-2018 01:24 AM
  17. r511's Avatar
    Not at all.
    Just watch YouTube on how to run ADB Shell.
    06-15-2018 01:30 AM
  18. scottbeamer's Avatar
    Not at all.
    Well for starters, I don't have access to a computer...
    06-15-2018 01:32 AM
  19. r511's Avatar
    That's a problem then.. Lol
    06-15-2018 01:34 AM
  20. scottbeamer's Avatar
    Even if I did, I would not want to put that much effort into it.
    recDNA likes this.
    06-15-2018 01:48 AM
  21. Luke pruitt's Avatar
    Depends on how much you want the tweak. Here's the effort: have adb or platform tools on the computer, plug phone in, open SamTweaks folder and it does the adb permission by itself.
    06-15-2018 09:29 AM
  22. UdiBerry's Avatar
    It seems that every phone has a different behavior.
    On my S9+ I get the volume warning only once after restarting my device. If I tap OK, I can control the volume freely with no warnings until the next restart (which I rarely do anyway).
    06-15-2018 10:03 AM
  23. strikeIII's Avatar
    Go to Settings - Sounds and Vibration - Volume - tap the 3 dots on the top right corner, Media Volume Limiter. Turn it On and set the custom volume limit slider all the way up.
    EDIT: Neveremind, I don't think this removes the pop up.
    06-15-2018 04:53 PM
  24. r511's Avatar
    That does not work. Would be great if it did!
    06-15-2018 05:36 PM
  25. r511's Avatar
    They legally have to add these warnings I believe.
    For our devices, Sam Tweaks is the only answer.
    06-15-2018 05:41 PM
29 12
  1. Replies: 11
    Last Post: 10-16-2018, 05:45 PM
  2. Moto G5 Plus Volume
    By 1countryboy in forum Moto G5 & G5 Plus
    Last Post: 06-12-2018, 09:54 AM
  3. Moto G5 Plus Volume
    By 1countryboy in forum General News & Discussion
    Last Post: 06-11-2018, 11:03 PM
  4. Volume randomly lowers and go back to normal
    By Trizorg in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 06-11-2018, 10:59 PM
