1. Katsuraz's Avatar
    I've been using Nova Launcher Prime with my Galaxy S8+ since it came out last year. Locking the phone with "Timeout" method had been working flawlessly.
    Last week, I switched to S9+ and imported my Nova Launcher settings from my old S8+.
    At first, I thought the screen locking works fine as it was in my S8+ but sometimes I noticed, it needs me to enter my password as required by the security policy instead of using biometrics.
    I re-checked my screen lock method in Nova Launcher to make sure it is set to timeout, remove all my fingerprints and register it again, tried to activate/deactivate device admin permission for Screen Lock Nova Action, restart the phone several times. It still often needs me to enter my password instead of letting me use my fingerprints. This becomes really frustrating for me having to type my password when I'm in hurry getting into my device.
    Anyone know where did I get it wrong?
    06-14-2018 11:16 AM
  2. B. Diddy's Avatar
    This has been normal behavior on all of my recent phones (Pixels and Nexus) -- from time to time, the phone will ask the user to reenter the backup password/PIN/pattern for added security. It might be if the phone hasn't been unlocked for a certain duration, or if there have been a couple of unsuccessful fingerprint unlock attempts. Can you give us a better idea of how frequently it's happening?
    06-14-2018 11:33 AM
  3. Katsuraz's Avatar
    Very often. After I read your reply, I tried locking my device with Nova gesture and leave it untouched for about 10 minutes. I picked up my phone and it needs me to draw my pattern rather than using my fingerprints.
    If I try to unlock the phone after locking it with Nova gesture immediately, the biometrics will work fine.
    06-14-2018 11:57 AM
  4. B. Diddy's Avatar
    Do you need Nova to do the screen lock? That feature might be interfering. Try going to Settings>Security>Device Administrators and uncheck Nova. Now see if the problem persists.
    06-14-2018 01:25 PM
  5. Katsuraz's Avatar
    It was already unchecked. I used the timeout method that doesn't need device admin to turn the screen off.
    06-14-2018 02:05 PM
  6. r511's Avatar
    You have to choose the second lock option in the popup window when you set up the screen lock.
    I can't remember what it says.
    I'm using Nova with double tap to sleep and I have zero issues unlocking with fingerprint.
    06-14-2018 04:15 PM
  7. rigosj's Avatar
    Remove all the device administrators one by one. I am sure this will solve the problem.
    For me it was the Greenify that caused the problem.
    10-22-2018 04:40 AM
  1. Are We Going to Get Any Verizon Updates?
    By recDNA in forum LG V20
    Last Post: 06-16-2018, 12:50 PM
  2. Someone has my phone hacked and is reading my messages and listening to my calls
    Last Post: 06-14-2018, 02:17 PM
  3. Automatically updating file on USB Storage (using a Wingle USB Router perhaps?)
    Last Post: 06-14-2018, 12:23 PM
  4. How do I get rid of the donut icon when texting
    Last Post: 06-14-2018, 11:45 AM
  5. why is my powered down phone hot to the touch?
    Last Post: 06-14-2018, 11:12 AM
